Jaguar Engines & transmissions Discuss performance / modifications / upgrades etc here..
92mm MAF installed. Yeah baby !!
Old May 15, 2013 | 08:04 AM
  #41
Michael Star's Avatar
When I got my intake tube I had it ceramic coated which was supposed to not heat up as much or something like that.
http://www.jet-hot.com/
Old May 15, 2013 | 08:15 AM
  #42
steveinfrance's Avatar
Painting it black will make it absorb engine bay heat more effectively, cancel out the anti-alien effects and give you ear cancer from cell phone radiation.
Old May 15, 2013 | 08:43 AM
  #43
ccfulton's Avatar
Aluminum.
You don't want the aliens scanning your MAF signal and using that information to take over the earth!
Old May 15, 2013 | 10:17 AM
  #44
WaterDragon's Avatar
Don't you all know, they are already here. (Cue the eeery music)
But, apparently, they only talk to cows, and Cartman.
Actually, news flash, I am now patent pending on a more practical version of my intake air cooling SCRAMJET idea, so this intake is only temporary. Also, this is wayyyyyyyyyyyy too ugly to be paired with the painted charge coolers that will be going on later.
I'll replace it with a prototype of the SCRAMJET when I get that far.
Old Jul 14, 2013 | 11:18 AM
  #45
Since I have been getting numerous PM requests about wiring my 92mm MAF I'm adding this info:
Here is how I wired my 92mm MAF successfully using their pigtail connector:
Wires on the 92 Pro M--------Wires on stock MAF
A: power-------white, blue stripe
B: Ground
C:Ground
D: MAF signal--------Green, white stripe
E: IAT voltage---------Orange This wires to replacement IAT sensor to original harness/connector
F: Ground
I really like to use these awesome connectors so you don't screw up the original wires, these posi-taps are the way to go!
Posi-Tap- No Crimp Tap
WhiteXKR introduced me to these connectors-they are the best!
Old Jul 14, 2013 | 12:53 PM
  #46
Me likies.
Old Dec 13, 2016 | 11:52 PM
  #47
ET1's Avatar
ET1
Would there be any issues running the ProM 92mm MAF on my 2003 XKR? Would I need the additional IAT Sensor?
Old Dec 14, 2016 | 03:11 AM
  #48
XJR-99's Avatar
[QUOTE=ET1;1585212]Would there be any issues running the ProM 92mm MAF on my 2003 XKR? Would I need the additional IAT Sensor?[/QUOTE
No issues if your engine is 4.0. You need additional IAT sensor.
Old Dec 31, 2016 | 01:14 PM
  #49
Default part number and source
I bought my larger MAF from Pro-M. It appears to be a very good unit, but be aware that you will need to source and wire a separate IAT sensor, as the PRO-M one is not correct for the Jags. I bought my sensor at the dealer part # LCC1602AA at Gaudin in Nevada for $74.
Old Apr 14, 2017 | 06:24 PM
  #50
ET1's Avatar
ET1
Finally finished the fuel rail and Eaton rebuild and reinstalled everything and it runs fine.
I'm trying to install my Pro M 92mm intake and realize that I got a 4 wire pigtail from Pro M.
That's what Chris at Pro M told me I needed.
I notice that Water Dragon has a 6 wire pigtail on his Pro M.
I got the separate IAT sensor to splice in.
Three questions:
Do I need the 6 or 4 wire pigtail?
Do I need the external IAT sensor wired in?
I have the wiring diagram or schematic that Water Dragon posted for the 4.0l. Is it the same for the 4.2l?
**This a 2003 XKR 4.2L AJ34 engine.
Old Apr 15, 2017 | 01:36 AM
  #51
JagV8's Avatar
Circuits are in the free download workshop manual and other sites on the net - you failed to say your car but it covers them all. 99.9% you need every sensor.
Old Apr 23, 2017 | 11:08 AM
  #52
ET1's Avatar
ET1
Thanks JagV8, got the schematic and it looks like the harness is the same on the 4.0 and 4.2.
ANYONE? Is the 4 wire pigtail appropriate for my 2003 XKR with the 4.2 vs the 6 wire?
I have it hooked up and it runs, albeit with Restricted Performance and a P0103 Code
Mass or Volume Air Flow Circuit High Input"
Old Apr 23, 2017 | 05:24 PM
  #53
ET1's Avatar
ET1
Hi All,
I've read all the posts about installing the Pro M and wiring it correctly but can't get it right for installing my Pro M 92 MM intake. I keep getting P0102, P0103 (high and low input signal) and P0112 ( low signal from IAT sensor.) and restricted performance..of course.
I tried to zoom in on the wiring pic posted by Water Dragon, but it's blurry and the wires are all wrapped in black tape.
I have a 2003 XKR 4.2 and when I asked Chris @ Pro M for a schematic of how to hook it up this is what he sent. See email and diagram.
It seems incomplete and I asked whether I need the 4 or 6 wire pigtail for the intake. His response is in the attachment... not clear to me. The 4 wire schematic/diagram he sent is totally different from Water Dragon's description of the Pro M wiring schematic.
I do have the IAT probe.
Any advice or a pic of exactly what connects to what?
Thanks,
Evan
I'm calling him tm bright and early.
Old Apr 23, 2017 | 11:55 PM
  #54
avos's Avatar
As Chris mentioned, the Pro-M IAT (Intake Air Temp sensor) is different to our cars, so not usable. The wire colours given for your 2003MY look good to me, are you sure you connected it correctly?
Old May 3, 2017 | 10:38 AM
  #55
ET1's Avatar
ET1
@avos, I may have fried the unit miswiring it. It's back at Pro M, where they will recalibrate, or repair it.
Old May 16, 2017 | 12:08 PM
  #56
ET1's Avatar
ET1
I have the PRO M 92mm meter back after damaging it and followed Pro M's wiring diagram EXACTLY and now have only "Restricted Performance" and a P0102 Mass or Volume Air Flow Circuit Low Input. (See pix)
I didn't even start the car and had this warning pop up with the key turned on to accessories/system test position.
When I reinstall my OEM meter, the car runs perfectly with no codes.
PRO M says the problem is on my end.
What am I missing???? Any wiring advice????
Old May 16, 2017 | 12:37 PM
  #57
avos's Avatar
With a multimeter, what voltage do you measure between Red and Black/brown, and Blue and Black/Brown with ignition on?
What happens if you start the car?
Old May 17, 2017 | 12:47 PM
  #58
ET1's Avatar
ET1
@Avos, Pro M is out and OEM is in so I can use the car. I will reinstall Thursday or Friday and answer your queries then. I didn't want to start the car until I was sure the connections were correct. I didn't want to damage the meter again.
To be clear: "With a multimeter, what voltage do you measure between Red and Black/brown, and Blue and Black/Brown with ignition on?"
"Ignition on" = car NOT started, correct?
Old May 18, 2017 | 02:19 AM
  #59
avos's Avatar
Indeed, 1st measure only with ignition on, so no start.
Old May 18, 2017 | 02:25 PM
  #60
ET1's Avatar
ET1
@Avos
What happens if you start the car?"
Voltage between Red and Black/Brown is 11.85
Voltage between Blue and Black/Brown is 0.02
Car stalls after repeated attempts to start and clear codes.
I also checked the Vehicle blue/white lead against the ground (Black/white) lead with neither meter connected and and got a solid 11.75V.
Suggestions?
