Jaguar Engines & transmissions Discuss performance / modifications / upgrades etc here..
92mm MAF installed. Yeah baby !!
Old May 19, 2017 | 12:08 AM
  #61
avos's Avatar
The 0.02 voltage is not good, and I would say something is wrong with the unit, as the start voltage should be much higher (don't know by head). I thought that maybe when there was flow (so once you start), the voltage would go up and the car could be running. Best is to do the same measurement with the stock MAF, and inform Chris of what's wrong.
Old May 19, 2017 | 02:42 AM
  #62
ET1's Avatar
ET1
Thanks Avos, I'll do that tomorrow with the OE MAF..
Old May 19, 2017 | 03:12 AM
  #63
avos's Avatar
Np, the voltage should start from 0.6 ish something, so the meter isn't ok or an incorrect tune is loaded, so providing Chris the right start voltage should help him determine what could be wrong.
Old May 19, 2017 | 11:53 PM
  #64
ET1's Avatar
ET1
I couldn't get the car to start and run for more than a second or two.
Reinstalled OE MAF, cleared codes and it runs perfectly. The voltage is 11.75 from the hot lead and the MAF signal (green lead to ground is a solid .68V..you called it.
I'm disgusted and sent the unit back for testing.
I followed the install directions EXACTLY this second go around as the miswiring was an expensive mistake. I took several close up pix for confirmation as you have seen. I did quite a bit of research on MAF wiring and problems today.
I wish I had done that before connecting the Pro M up the first time.
I posted the pic here and also fwded it to Pro M. I haven't gotten a response to the picture yet.
Thanks again for your advice
ET
Old Feb 2, 2018 | 07:54 AM
  #65
User 070620's Avatar
going to buy it
jimforrest (uk)
Feb 28, 2019 06:42 PM
10 XF Premium
Oct 2, 2015 09:22 PM
Lubrication
Oct 1, 2015 03:56 AM
mrplow58
Sep 30, 2015 08:56 AM
