Jaguar Engines & transmissions Discuss performance / modifications / upgrades etc here..
Aj v8 timing wedges?
Old Nov 9, 2012 | 02:49 PM
Sean B's Avatar
Default Aj v8 timing wedges?
Has anyone got them to give me dimensions? thanks in advance
Old Nov 9, 2012 | 08:43 PM
plums's Avatar
.. umm .. what are they?
bump!
Old Nov 9, 2012 | 09:37 PM
jchavez76's Avatar
Primary Timing Chain Wedges - 303-533
I'm pretty sure this is what they are. I don't have them. I used one of my plastic trim wedges. Worked very well and they're cheap. Amazon has a set of trim wedges for 11 dollars.
Old Nov 10, 2012 | 01:15 AM
plums's Avatar
Someone mentioned using a couple of screwdrivers for that job.
Old Nov 10, 2012 | 07:21 AM
Sean B's Avatar
That's what I've been doing, but for completeness I'd like to make some wedges ala Jaguar...
Old Nov 10, 2012 | 08:47 PM
motorcarman's Avatar
If you fit the newer metal body primary tensioners then they will ratchet out and NOT retract without holding the lever. The tools were used with the plastic tensioners that had 'o'rings and check valves.
Once the new primaries are released you won't get much between the tensioner and the guide blade. You might try some feeler gauges or really small wedges.
bob gauff
Old Nov 11, 2012 | 02:54 AM
plums's Avatar
If you fit the newer metal body primary tensioners ...
Are the newer metal ones well into the supply pipeline now or are the older plastic likely to popup at the door?
Old Nov 11, 2012 | 08:39 AM
I have a Ford Dealer local to me so I just get the metal tensioners from them. They are a little cheaper than the Jaguar ones.
bob gauff
dsnyder586
Dec 29, 2024 07:39 PM
Wolfy
May 28, 2024 08:06 AM
PMKimpton
Aug 3, 2019 08:22 PM
nitrolouie2142
Sep 5, 2015 01:55 PM
Sprayall
Sep 3, 2015 07:49 PM
