Jaguar Engines & transmissions Discuss performance / modifications / upgrades etc here..
Who here has wired up a Boost A Pump?
Old Jul 25, 2013 | 10:21 PM
WaterDragon's Avatar
Default Who here has wired up a Boost A Pump?
I just ordered a GT500 Kenne Bell Boost A Pump for my 2000 XJR.
I wanted to get ready and get whatever info I can before it arrives.
I understand I will use a pressure/boost switch to activate, and splice into the power feed lines for the pumps.
Update 7/29/13
Jim Lombardi (thanks again Jim) posted this schematic for me https://www.dropbox.com/s/7075tcbswn...nformation.jpg which shows the likely candidates for splicing into are the orange and brown with green stripe wires after they come out of the relays and before the pumps.
When this is installed I will report back so everyone who wishes to "travel" this route can have the benefit of "one who has gone this way before..."
Old Sep 21, 2013 | 03:11 PM
matts89xj's Avatar
I've always run Bosch 044 in aggressive build or a MK4 supra twin turbo pump.
Old Sep 21, 2013 | 05:13 PM
plums's Avatar
BTW, there was a guy running dual 44's with dual #10 to the pumps and a shared #10 ground. He changed to dual #10 grounds and picked up 0.5 to 0.8 volts at the pump with no other changes.
That's pretty good evidence that the wiring has to be fully sorted instead of, or before, installing a BAP.
Old Sep 21, 2013 | 11:52 PM
kompressed_xj's Avatar
I'm interested in the results WaterDragon
Old Sep 22, 2013 | 06:33 PM
ronbros's Avatar
i'm all about large wiring for fuel pumps and relays, a popular mod back around 10-12yrs ago was ,adding more ground connections, with #8 wire, some guys say it helped stray electronic signals from getting into ECUs,or other places, acted like a shield of sorts.
Old Sep 22, 2013 | 07:16 PM
When I have a dyno it ought to show afr with and without the BAP. I'll post when I have it.
dsnyder586
Dec 29, 2024 07:39 PM
mrplow58
Jan 21, 2024 05:53 AM
roby
Sep 20, 2015 01:54 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
1964Daimler
Sep 9, 2015 11:28 AM
