Door Trim
Old Jul 6, 2010 | 02:20 PM
majbill's Avatar
Default Door Trim
Recently I noticed a couple of my door trm panels have started to come lose on my 2002 VDP. How are they adhered to the door? double sided tape? spray adhesive?
Thanks,
Bill
Old Jul 6, 2010 | 03:04 PM
Stu 1986's Avatar
Which part of the door do you mean? The wood veneer or the actual entire door card? Both are held on with clips, which are cheap and easy to come by if you find yours are broken/missing.
Old Jul 7, 2010 | 08:17 AM
majbill's Avatar
Default Door Trim
It' just the front doors and is the veneered wood trim. Not the veneer itself but the piece on the door panel and it is just in the corner closest to the seat. The rest is in place just fine.
Bill
Old Jul 8, 2010 | 03:05 PM
Stu 1986's Avatar
Hello Bill, as silly as this will sound, why not try sticking the trim down with something like Silicone? This can be hidden easily behind the panel as you will only need a small amount and it's easily removed also should you need to remove the pannel for any reason. Either this or a double sided sticky pad.
Old Jul 9, 2010 | 08:12 AM
majbill's Avatar
Default Door Trim
Great minds, Stu. I had not thought of the silicone but was thinking since it is only the corner of the driver's door and the passenger door of using doubled sided tape. The rest of the trim on both doors is fine and this is not sticking way out. When you were thinking of silicone were you meaning like a silicone putty?
Thanks,
Bill
Old Jul 11, 2010 | 03:18 PM
Stu 1986's Avatar
Glad you found a fix that worked. I meant the silicone that comes out of a tube, like what you might use in a bathroom. We use it at the depot for sealing the floors of buses, or areas of the bus which requires protection from water. But it is also pressed into service as a glue when a easy removed solution is required.
Ta, S.
Old Sep 29, 2010 | 08:28 PM
majbill's Avatar
Default door trim revisited
Okay, haven't revisited this in a while. Tried the double sided tape but did not work. I didn't want to remove this wood door trim (both front doors have the problem). Not sure I want to try the silicone methog recommended. What's the best fix...how do I remove these pieces from each door?
Thanks.
Bill
Old Sep 30, 2010 | 06:33 PM
jimlombardi's Avatar
Default JTIS extract on XJ8 door veneer panel r&i
Here is the PDF file extract for door veneer panel r&i. Click on the PDF file name:
5) 98 jaguar xj8 front door finish panel 76.47.11.pdf
I put out a reply yesterday on door mirror thread for r&i
If you want to see the rest of the PDF files that give all the instructions on how to remove and install the front door panel then
click on this website link:
https://www.jaguarforums.com/forum/s...ad.php?t=42677
Go down to reply #6
Titled: Second post on Jaguar JTIS information on XJ8 door mirror r&i
Poet
Oct 6, 2015 09:40 PM
hologram1954
Sep 16, 2015 02:43 AM
SeanU
Sep 14, 2015 04:31 PM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
1964Daimler
Sep 9, 2015 11:28 AM
