1958 mk1 jaguar build
Old Dec 28, 2014 | 10:50 PM
58mk1x2's Avatar
Default 1958 mk1 jaguar build
mill bellhousing to fit Toyota 5 speed box
jag meets toyota
I've started with milling the jaguar bellhousing to fit a Toyota w50 5 speed manual gearbox and it fits using Toyota clutch and pressure plate all I need is to turn up a bush for the back of the crank shaft.
Old Dec 29, 2014 | 11:09 AM
JeffR1's Avatar
That's an impressive mod ! If that Toyota transmission is any thing like the one in my Mazda B2200, then it will shift like a hot knife through butter. I had an old B2200 with over 800,000KM on it and the trans. never needed servicing _ I changed the oil when needed. I only stopped driving the truck because the frame rotted out.
Will the speedo cable fit on the Toyota trans from the jag and if is so will it be accurate ?
Old Dec 29, 2014 | 02:43 PM
DaimlerMK2's Avatar
Hi
and great job you are doing,
for us in the UK what is the Toyota w50 5 speed manual gearbox out of,
thanks,
Old Dec 30, 2014 | 12:41 AM
58mk1x2's Avatar
the gearbox came from a Toyota celica 18r 1978/1981, as for how accurate the speedo will be I don't know but Toyota have a big range of speedo gears so I see no trouble and I can get speedo cables made to order all to easy.
Old Jan 22, 2015 | 12:17 PM
58mk1x2's Avatar
Default brake upgrade
4 pot volvo
dual circuit master cylinder
brake upgrade with 4 spot Volvo's and dual circuit master cylinder.
Old Jan 22, 2015 | 12:37 PM
Jose's Avatar
would you mind detailing the engine please ?
Old Jan 22, 2015 | 08:08 PM
JeffR1's Avatar
Originally Posted by 58mk1x2
4 pot volvo
So with that Volvo master cylinder, you must be loosing your power breaks or are you utilizing the stock Jaguar vacuum booster ?
Oh, wait a minute, there are newer versions of that external vacuum booster with duel circuits, maybe that's the way you went ???
Old Jan 22, 2015 | 10:14 PM
58mk1x2's Avatar
jeff, the master cylinder is from a vw super bug and I will be using 2 vh40a boosters one in std jaguar place right side and the second on the left side copying std place with jaguar cover.
Old Jan 27, 2015 | 03:24 AM
58mk1x2's Avatar
it will be when I change the sump and oil filter and put on the polished bits.
paulyling
Mark V - X 420G
Aug 15, 2023 09:33 PM
SD96XJ6L
Jan 12, 2022 04:30 AM
Sprayall
Sep 3, 2015 07:49 PM
Harry Dredge
Sep 3, 2015 03:04 AM
Harry Dredge
Sep 2, 2015 02:26 PM
