1964 3.8S Resto Mod
Old May 30, 2025 | 02:08 PM
Egreg's Avatar
Default 1964 3.8S Resto Mod
A few Photos of my 4 year project:
12,500 USD invested in parts so far...
4.2 rebuilt engine from 1987 XJ6, BW35 trans, all LED lighting, Touch screen stereo with subwoofer, backup camera on license plate frame...
work in progress for a old guy with a bad hip...you should see how slow i work with a walker !
Old May 30, 2025 | 03:55 PM
Cass3958's Avatar
The Jaguar 420 with the 4.2 litre engine was never fitted with the BW35 gear box which was used in its sister Jaguar the 3.4 and 3.8 S Type due to the BW35 not being able to take the torque of the 4.2 engine according to Jaguar. The 420 was fitted with the Model 8 gearbox from earlier cars as it had a cast iron body where as the BW35 had an aluminium casting. The XJ6 4.2 was fitted with the BW65 and BW66 gear boxes. I believe
No doubt the BW35 will hold its own but try not to bury the right foot too often or the gear box might tear itself to pieces.
Old May 30, 2025 | 05:36 PM
Egreg's Avatar
it must be an bw65/66 because it was attached to a 4.2 fuel injected engine from a late 80's XJ6
i paid 500 bucks for the pair with torque converter, and the downshift is a cable
also i found an intake manifold with 2 Stromberg CD 175 carbs because im not able to do fuel injection, due to missing parts
i hear that the electronic distributor is set up with a vacuum diaphram for fuel injected engines and i have to change the advance cannister for more low end torque.
also the fact that this is a fuel injected head with larger intake valves might perform better than the older heads.???
Dapp3r
May 20, 2025 12:58 PM
giandanielxk8
Feb 27, 2025 04:50 PM
Paldi
Aug 21, 2024 02:16 PM
Queen and Country
Jul 20, 2023 01:15 PM
hm1
Aug 3, 2016 05:27 AM
