1967 Mk2 340 Transmission fluid
Your car should have the Borg Warner Type 35 transmission. Plate on LHS of the transmission.
These transmissions should be run on fluid containing no friction modifiers & meeting Ford spec. M2C 33 F or G. Generally known as Type F or Type G fluids. Does not matter which you choose.
While the range change might be slightly smoother, Dexron fluid allows excessive slip of friction materials (bands & clutch packs) leading to overheating and ultimate failure in a Type 35 transmission.
General Motors that owns the Dexron brand fitted large clutch packs to their transmissions that could tolerate delayed lock up & thus not overheat. Ford/Volvo BW 35/65 etc had the opposite philosophy and wanted quick clutchpack lock up.
NO Dexron should be used unless the transmission has been modified & all friction materials replaced. Even then the components are actually too small to dissipate heat with slip. A large transmission cooler should be fitted. Not the standard 35 cooler. Far safer to stick to Type F or G fluids.
Wasn't Type A originally specified, which evolved to Dexron II? I was always under the impression it followed the Dexron superscession line, not the Ford line.
No ~ The GM/Benz Type A Suffix A fluids made with cold sulphurised sperm whale oil were closer to & preceded Type F fluid (no friction modifiers). The GM/Ford philosophy split that had been building for a while finally took place in 1959. Jaguar & Borg Warner, Volvo etc. specified Type F for this gearbox specifically from inception. Dexron type products are too slippery for the Type 35 & will lead to clutchpack burnout. All Dexron products have friction modifiers in them that allow controlled clutchpack slip before lockup.
What matters is that BW designed this box to run on Type F fluid.
