"Arctic Kar" A/C wanted
Old May 13, 2018 | 10:05 AM
rdssdi's Avatar
Default "Arctic Kar" A/C wanted
I am looking to purchase an Arctic Kar A/C unit (as pictured) for a MK2 sedan. Thanks Bob
Attached Thumbnails "Arctic Kar" A/C wanted-j61-774-027.jpg
Old May 13, 2018 | 03:01 PM
George Camp's Avatar
Default Rear evaporator
The one pictured may be available NOS (contact off line). The one in your pic is a bit small (note the coffin shape of the other). These were used in many cars but the one pictured was the one specified. Not that the shop that installed it used what they had on the shelf. the one you posted has been modified as far as the gas lines are concerned--the HI and Low were in the engine bay orig. In anycase I know where some NOS resides so if interested let me know.
Old May 13, 2018 | 03:03 PM
just checked your address--it is Earth so we are good!
Old May 13, 2018 | 06:15 PM
jagstuart's Avatar
how soon do you need it? working order? would a Koolair brand from my 3.8S with trunk mounted evap and parcel shelf registers work for you? dryer is in engine bay and hoses run along frame rail to rear. period electric fan assist at radiator.
Old May 14, 2018 | 09:15 AM
The 'S' kit will work in a MK2 but was up scale if it was the approved kit. The cold out vents were molded devices that ran up the C pillar---will look for a pic. they also had a form fitting cover for the evaporator as the Fan motors were re located--also very finished looking.
Old May 14, 2018 | 08:07 PM
jagstuart's Avatar
here's paperwork for a koolair for an mg/austin healy ( same difference as jag unit)
Old May 15, 2018 | 05:49 AM
Will post a few documents for the 'S'. I copied the front of the brochure in B/W as it makes the unique outlets very obvious. The install documents run some 50 pages. Jaguar USA worked very hard with the two major vendors on their kits. this one for the 'S' is well developed but not the final version. Enjoy---in future post
Old May 15, 2018 | 06:26 AM
rdssdi's Avatar
Default compressor mounting
I am using a "modern" rotary compressor. I was able to locate an original period York compressor mounting bracket, double crank pulley and idler. I utilized a universal mounting bracket for "York piston" to "rotary" compressor installation. Installation of retroair's alternator with the rear power steering pump take off completed the job.
Trial fit.
Old May 15, 2018 | 07:52 AM
Jose's Avatar
I have the brackets and old compressor from a 1964 MK2 RHD that came from Japan to the US.
Old May 15, 2018 | 09:18 AM
Default Coolair
Here are the CoolAir ads and part of the instructions. Now if I could rotate the images!
Old May 15, 2018 | 09:25 AM
the only downside for a non original compressor besides originality is the loss of the isolation valves. Many times on a MK2 or similar the compressor needs to be removed to work on other issues. With the orig. valves you can isolate the system and you loose only a breath of gas. That said you can also use the valves to self vacuum the system to test and prepare for refill---very handy!
Old May 15, 2018 | 09:27 AM
BTW here is the shroud modification--it is very accurate.
Old May 15, 2018 | 10:31 AM
rdssdi's Avatar
I have that chrome cross bracket with ancillary brackets. I could use it with the rotary compressor. It is likely not necessary. I have not yet decided. It may reduce stress on the main bracket to block mounting. What is the purpose of the side and bottom shroud cut outs?
Old May 15, 2018 | 10:35 AM
You have added a pulley and an additional belt. they will need a place to run. That said these drawings are for the period Ac kit. Your angles and such may be a bit different. You do need the shroud though and it is a PITA to install!
Newjag
Feb 4, 2019 12:10 AM
Busa196
Jan 11, 2018 05:14 PM
JimC64
Feb 12, 2012 06:05 PM
45Wheelgun
Oct 5, 2011 03:44 PM
afonda
Mar 8, 2011 01:48 AM
