Engine rebuild question - last mile
Old Jun 1, 2018 | 03:01 PM
daftwankie's Avatar
Default Engine rebuild question - last mile
Hi All,
We are rebuilding the engine of a MK2 3.8 liter (1960). We are in the home stretch, but have hit a snag. We get a high voltage spark upon turning ignition on and another spark when we turn ignition off. But when we test the spark plugs, we get nothing. Have replaced coil, distributor cap, plugs and wires. Any ideas?
Thank you.
Rob
Old Jun 1, 2018 | 05:46 PM
Robman25's Avatar
Are the points wired in correctly?
Old Jun 1, 2018 | 05:49 PM
daftwankie's Avatar
Default I believe so...
Bought new points yesterday and there are only two wires to attach when installing.
Old Jun 1, 2018 | 07:30 PM
JeffR1's Avatar
Originally Posted by daftwankie
Hi All,
Thank you.
Rob
You have to eliminate variables.
The coil is OK because you have spark.
Depending if your car is positive or negative ground.
Temporarily hook the coil directly to the 12 volt side of the battery to make sure it's getting 12 volts.
This will by-pass the ignition circuit.
If the car then has spark and starts, then the problem lies with in the ignition circuit somewhere.
If the car is positive ground, the positive side of the coil will go to the distributor and the negative side will go to the negative side of the battery.
If the car is negative ground, then the positive side of the coil goes to the positive side of the battery and the negative side of the coil goes to the distributor.
When doing this test, disconnect the ignition side line from the coil.
If it still does not fire when bypassing the cars ignition circuit, then check the small braded copper line inside the distributor.
Make sure that it's connection are good and that it's not shorting out anywhere inside the distributor.
Make sure that your points are installed correctly as well, there is a small collared nylon washer that isolates the points where the flexible braded line is secured to.
The nylon washer isolates the points from ground, but not the braded copper wire.
Also, when connecting the coil directly to the battery, do not leave it connected in this way for more the a couple of minutes with out the car running.
If the points happen to be closed, voltage from the battery will heat up the coil.
Also check to see if the rotor is turning when the car turns over.
Another member had missed putting the role pin in the drive gear on the end of the distributor shaft.
You can also grab the rotor and it should not turn. This is to make sure that the role pin is actually in place.
Old Jun 2, 2018 | 12:13 AM
TilleyJon's Avatar
Rob, when you say you are getting a spark when you turn ignition on, and when you turn it off, can you explain where you are checking for this spark.
Are you saying that you are getting a single spark from the coil when you turn on the ignition, and another spark when you turn the ignition off, but nothing when you crank the engine ?
Old Jun 2, 2018 | 07:37 AM
daftwankie's Avatar
TillyJon: Exactly.
Old Jun 2, 2018 | 10:41 AM
daftwankie's Avatar
Success! The point wasn’t wired correctly. The capacitor wire and low-voltage wire were on top side of the flange, not the bottom, so they weren’t making contact with the points spring. We now have sparks to the plugs.
TreVoRTasmin
Aug 3, 2016 07:12 AM
ruski
Oct 9, 2015 06:07 PM
Justink201
Jun 13, 2014 07:01 AM
Cambo
Europe
Apr 24, 2013 02:37 PM
abonano
Mar 8, 2012 06:09 PM
