Fueling
Old Aug 27, 2025 | 08:28 AM
Martin Mark2#'s Avatar
Default Fueling
Coming back from a show we experienced some severe missing which then cleared completely At home it played up again.I found both jets in one carb were blocked.
I have fitted two parallel disposable filters before the pump and replaced the under bonnet one.
I also cleaned out the float bowls.
Unfortunately the banjo connectors then leaked and I spent ages getting fibre washers which was very difficult. I ended up with a very helpful Lynn at Southern Industrial Fasteners 07711721911.
The carb internals were also dirty due to the breather pipe entering the inlet of the air system so I wondered if anyone has disconnected it and used a different termination?
Old Aug 27, 2025 | 09:37 AM
Peter3442's Avatar
https://www.jaguarforums.com/forum/m...eather-290495/
We had some discussion of alternative breather arrangements recently - see the link above. Still, there shouldn't be so much oil/dirt coming through the breather.
Old Aug 27, 2025 | 09:55 AM
Thank you for the advice. There are minimal fumes but 58 years worth!
Old Aug 28, 2025 | 07:03 AM
Bill Mac's Avatar
I suggest you also check the in-tank filter.
They can be partially blocked to a degree which will stop the car after a mile or so.
It's a not uncommon problem in MK1 and MK2 cars.
Old Aug 28, 2025 | 10:33 AM
Thank you.
ray40
Jan 30, 2024 12:29 AM
AL NZ
Apr 27, 2016 04:38 PM
gmacaz
Feb 11, 2016 02:58 PM
Rhett
Aug 14, 2014 10:47 AM
Jagxjs
Feb 5, 2013 06:14 PM
