generator or alternator
Old Feb 24, 2019 | 12:14 AM
jagstuart's Avatar
Default generator or alternator
The car came with a aftermarket a/c unit. It has a rinky-dink four blade pushing fan between the grill and the condenser coil. I'm wondering about the draw on the generator with the a/c and fan. I'd like to replace the stock fan and the add on a/c fan with a good (2500-3000 CFM), https://www.summitracing.com/parts/flx-168/overview/ ,pushing electric fan. This post had somethings to say about the abilities of the original generator:https://www.jaguarforums.com/forum/m...ersion-202117/
Any comments or help appreciated. - Stu
Old Feb 24, 2019 | 02:03 AM
TilleyJon's Avatar
That new fan takes almost 20A , so may well have an effect on the dynamo's ability to keep up, what Dynamo do you have fitted at present ? If you have been reading the Air Con thread and it's contents, you will have seen that there was a need to upgrade to a 60A alternator when there were issues with night driving with lights on and AC.
The biggest benefit of the Alternator over the Dynamo is that is gives a higher output at low revs.
Old Feb 24, 2019 | 04:42 AM
Glyn M Ruck's Avatar
Yes ~ the standard 30 amp dynamo & even the "uprated" 35 amp unit is unlikely to keep up with mod cons fitted to the vehicle.
There are a range of Dynalites that look original & are available with PAS pump offtake. Up to 60 amp IIRC.
PAS pump offtake
And not look alike but will accommodate PAS pump & output 65 amps.
Old Feb 24, 2019 | 09:58 AM
TilleyJon's Avatar
Who makes the last Alternator with the take off Glyn ?
Old Feb 24, 2019 | 10:56 AM
Jose's Avatar
Stu,
check with Retroair if you want to convert to alternator, he has one if your car has power steering and another alternator for S type without p/s.
Dynamo to Alternator Kits | RetroAir, Inc.
Old Feb 24, 2019 | 04:30 PM
XK's Unlimited supply. Now owned by Moss. I would go Dynalite. Like the Retroair supplied unit the XK's unit requires conversion back to the single "V" belt. Really for early Mk2
Kurtuffles
E type ( XK-E )
Aug 29, 2017 09:29 AM
bookman
Nov 10, 2014 10:17 AM
DrkNyte
Oct 17, 2014 07:56 PM
christianbrustlein
XK120 XK140 XK150
Oct 13, 2014 05:06 PM
shoeboy
XJ40 ( XJ81 )
Apr 27, 2011 10:05 AM
