How the furflex is attached ???
Old Jun 2, 2020 | 01:54 AM
roman_mg's Avatar
Default How the furflex is attached ???
Hello, I am newbie on this forum.
I made myself happy and bought a Jaguar 3.8S. I'm at the beginning now and I think it will be a project for at least a year or two.
Now I am dismantling the interior (the body must be sandblasted) and I have one question, please.
What is the material of the pad in the body to which the furflex is attached ? Wood, rubber ?
It is possible to buy it ? Does it have an original Jaguar number ?
Is there anything that can be replaced ?
Thanks Roman
Old Jun 2, 2020 | 03:45 AM
Homersimpson's Avatar
I think its called tacking strip, from what I remember its very expensive so if you can save it I would.
Old Jun 2, 2020 | 04:21 AM
JeffR1's Avatar
Looks like "hood welting" "bonnet welting".
Here some examples, but if you Google the above more will come up.
https://replacementpartsinc.com/pre-...onnet-webbing/
https://www.ebay.com/itm/******-Jeep...-/271259267676
Old Jun 2, 2020 | 04:42 AM
roman_mg's Avatar
Thanks, but it is cca 1 cm x 1 cm (square cross section).
Old Jun 2, 2020 | 04:44 AM
roman_mg's Avatar
Thanks, I am trying to save it, but some small parts are damaged. I will try to find a replacement.
Old Jun 2, 2020 | 05:17 AM
JeffR1's Avatar
Maybe this, the 3/8 X 1/2 might be close enough.
https://www.bobdrake.com/tackingstrips
Old Jun 2, 2020 | 04:13 PM
jerry_hoback's Avatar
I have shreds of what you are referring to left in my 66. Harking back to my days as a Mopar guy when I had a 62 Newport, those cars had that stuff too. It was the trim at the edge of the door opening on the body side. Back then I understood it was called "windlacing" and it was held in by nasty sharp little clips. I got mine at JCWhitneys. Nuff said. Good luck
Old Jun 2, 2020 | 05:14 PM
Fraser Mitchell's Avatar
I did a quick search on-line and found this: --
https://www.jjautofabrics.com/tack-s...ontinuous-yard
and this
https://www.ebay.co.uk/itm/Universal...-/163612563675
When I rebuilt a Mark 2 in the 80s, I was able to find an unused shell, which had no tacking strips installed, but I was able to take the strips off the shell that I scrapped. They are very hard to remove because they are held on with "screw nails". These are hardened steel with a very coarse thread and hammered in making a hole as they go in. If you can find a scrap body 60s Jaguar body shell somewhere, you might be able to get the tacking strips off that. I doubt you can get the original stuff now, time has moved on too far.
Old Jun 2, 2020 | 05:20 PM
I just noticed your S-Type has a plate on the front with CD on it, is that a diplomatic plate?
Old Jun 2, 2020 | 09:22 PM
Glyn M Ruck's Avatar
Tacking strip is readily available from upholstery shops etc & screw nails or screw tacks from hardware stores.
Once my car was fully resprayed inside & out my upholstery man persuaded me that they were rubbish & not to use them. He used a heat curing glue to attach both the strip & the Furflex web. No knocking tacks through metal & chipping off paint & promoting rust.
Old Jun 2, 2020 | 09:31 PM
BSM's Avatar
BSM
I used the Furflex Tacking Strip supplied by Aldgridge Trimming in the UK and I used pop rivets to hold it in place instead of the spiral nails originally used.
Bruce M
Old Jun 2, 2020 | 09:47 PM
Pop rivets would work but 122 of the things is a curse. My guy used a heat curing glue that is a little like contact to hold things in place & then once in place you run over it with an iron & it cures. Did a great job.
Pre to attaching tread plates & top garnish rails.
With top garnishing rail & tread plates. Sorry ~ pics not taken for this purpose. Tread plate has black protective sticker over it other than the clamping lip.
All my material/upholstery kit from John Skinner UK.
Old Jun 3, 2020 | 02:18 AM
roman_mg's Avatar
Yes, it was diplomatic car in Vienna, Russian diplomat working for UN UNIDO. The car has been immovable for 20 years in Austria and I bought it last month.
JaguarXKR
Jun 2, 2020 09:29 PM
TexasTraveler
Apr 16, 2018 12:02 AM
Jaguar Forums Editor
E-Pace
Feb 5, 2018 10:14 PM
HarpersMuse
XJ40 ( XJ81 )
26
Aug 3, 2017 12:35 PM
69-300
XK120 XK140 XK150
Jan 5, 2017 09:13 PM
