MK 2 speedo oil leak
Old Oct 1, 2019 | 12:06 PM
tedjan's Avatar
Default MK 2 speedo oil leak
Hi,
I have gear oil leaking out of the speedo driven gear brass housing and I see there is a seal inside but I am not sure on how to separate the brass housing to access the little seal.This is the housing that the speedo cable attaches to on the o/d unit.
Can anyone help?
Thank you.
Ted
Old Oct 1, 2019 | 07:05 PM
Glyn M Ruck's Avatar
You remove bolt 84 to extract the housing. There is an outer O ring which frequently leaks & is easy to replace & an inner seal that can be more of a challenge.
Old Oct 2, 2019 | 11:29 AM
tedjan's Avatar
Thank you for that picture.Looks like it unscrews..
Old Oct 2, 2019 | 02:11 PM
Fraser Mitchell's Avatar
No, the thread in the pic is where the outer of the speedo cable is bolted up to the drive mechanism.
Old Oct 2, 2019 | 03:03 PM
It threads into the barrel & is pinned. I only had to fix an O ring leak on my car. I have never replaced the inner seal. You might well be able to fiddle a new inner seal in without unpinning & unscrewing.
My car runs a 90 degree angle drive screwed onto this unit to the speedo cable.
Old Oct 7, 2019 | 12:28 PM
tedjan's Avatar
Hi,
Would you have the part number for the inner seal?It is 3/4 o/d and 13/32 i/d.
Thank you.
Old Oct 7, 2019 | 08:38 PM
That inner seal is not shown as separate in the parts manual. The manual shows the unit as speedometer drive assembly C11929 & only the external O ring as separately available, or 10866 ~ Bearing assembly for later units. There were multiple minor changes to the overdrive units fitted.
My car has the longer bush.
Old Oct 8, 2019 | 05:44 PM
These damn bushes are expensive just for the sake of a new seal. I would drill out the pin. Disassemble the unit. Go in search of a new seal once you have a loose sample. Reassemble with new seal & re-pin/assemble with Loctite.
Old Oct 10, 2019 | 01:05 PM
tedjan's Avatar
Thank you,that's what we did,however we used 2 o rings and a spacer.
Dimension are 3/4" od,3/16" id,1/4' thick.
All fixed.
Old Oct 10, 2019 | 03:09 PM
All fixed.
Great!
mscott
Mar 15, 2019 05:10 PM
muttony
Sep 18, 2018 12:13 PM
MikeofBonsall
Aug 30, 2017 04:46 PM
jeremys
Jun 15, 2017 09:48 PM
Dan
Sep 20, 2012 10:23 AM
