Mk2 brake servo hoses
Old May 29, 2018 | 04:16 PM
geor-pett's Avatar
Default Mk2 brake servo hoses
Can anyone tell me if the two brake servo hoses, one going from the vacuum tank to the servo and the other from the vacuum tank to the inlet manifold both enter the engine bay through the hole in the bottom of the brake servo housing.
If so, what vacuum hose are you using as I purchased 3/8” vacuum hose (approx 19mm OD) and I’m struggling to get both these through the servo housing!!
thanks
George
Old May 30, 2018 | 03:34 PM
TilleyJon's Avatar
You are correct, and they are a tight fit !
It's easier to take the cover off and then put it over the pipes, you will really struggle pushing the 2 through the hole.
Old Oct 24, 2020 | 09:45 AM
Lovell Racing's Avatar
Hi,
Im restoring a MK2 3.8.The car was in bits when I got it Where and how is the Servo Tank situated please?
Old Oct 24, 2020 | 09:49 AM
Hi All,
Im new here so sorry if this has been covered before. Im Restoring a MK2 3.8, the car was in bits when I got it! Where and how is the servo tank situated under the fr.wing does anyone have a diagram or any photos please?
Ray
Old Oct 24, 2020 | 10:27 AM
Cass3958's Avatar
No photos I am afraid at the moment but the servo tank sits upright on the front chassis cross member right behind the front lights. It is bolted to the cross member with two bolts.
Old Oct 24, 2020 | 10:31 AM
Thumbs up
Cheers,
That's useful, I could really do with a photo or a measurement from the flitch panel if anyone has one
Old Oct 24, 2020 | 03:20 PM
Cass3958's Avatar
I will take a photo tomorrow for you and post it I just don't have one in the library.
Old Oct 24, 2020 | 05:52 PM
Glyn M Ruck's Avatar
Ray,
As I said in the other thread there is very little you won't find on Lin's valvechatter thread/blog regarding restoring a Mk2. Lin listed & photographed & diagrammed the entire process. Learn to navigate his blog by clicking main headings & all will open up. https://valvechatter.com/?p=2116
Brakes:
https://valvechatter.com/?p=4213
Good luck & enjoy! Shout if you need help. Don't hesitate.
Old Oct 25, 2020 | 03:17 AM
Cheers Glyn,
This is very useful, I cant seem to navigate the other site but Ill try again (maybe get one of the grandkids to do it!)
Regards
Ray
Old Oct 25, 2020 | 06:10 AM
That's fine. Then ask here & we will chase it up for you. Lot's of combined knowledge here. Cass & I have large libraries but they are mainly S Type.
Old Oct 28, 2020 | 01:23 AM
TilleyJon's Avatar
Originally Posted by Lovell Racing
Hi,
Here's another view
Old Oct 31, 2020 | 03:19 AM
Thank you all, this has been extremely useful! Now can anyone post a picture of complete engine bay minus engine so that i can see where all of the wiring, brake pipes, fuel lines etc, are located into which clips etc It would be very much appreciated!
Thanks in advance
Ray
Old May 7, 2025 | 01:41 PM
Lord_P's Avatar
Veteran: Navy
Veteran: Army
Jumping on this thread.... I have a servo, i have a single pipe to nowhere... I looked in the driver side wheel arch and i cant find the vacuum tank (62 Mk II) I eventually found it behind the passenger (right) side lamps... so where does this pipe go?
Old May 7, 2025 | 02:59 PM
Peter3442's Avatar
Hard to be sure, but it looks to me like the hose to the vacuum line from the inlet manifold. Have a look at the drawing in post no. 8 above.
Old May 7, 2025 | 04:26 PM
Lord_P's Avatar
Veteran: Navy
Veteran: Army
Suspect you are correct - its very "brittle" does anyone know the internal diameter and I might replace with rubber hose?
Old May 8, 2025 | 09:30 AM
Felixbobcat's Avatar
I believe the inner diameter is 8mm. I'll have to look where I bought my replacement hose. I think it was from a Porsche parts seller. If you look under the front of the car where the reservoir is mounted you should see a valve the controls where the air goes. You can get a measurement off of one of the ports. If you don't have the valve I've got an extra one you can have.
You will also need the T that is part of the system. The diagram above shows how everything is correctly plumbed.
Old May 8, 2025 | 10:02 AM
This is the hose I bought.
https://www.jbugs.com/product/N203761.html
Couldn't find any 8mm ID hose that was cloth braided. This stuff works fine, hose clamps keeps it tight since the ports are just over 9mm in diameter. Three feet was a perfect length for all the connections
Old May 8, 2025 | 10:37 AM
Lord_P's Avatar
Veteran: Navy
Veteran: Army
Next step is to jack it up and have a propper look. I just got the head back from the Machine Shop.
Thank you for your advice.
Old May 30, 2025 | 01:29 PM
Egreg's Avatar
dont forget the short metal rod at the top of the booster/servo cover that connects to that large vacuum tank to keep the vibrations down
Xjeffs
Oct 19, 2020 07:59 AM
new mexico
Apr 29, 2017 02:28 PM
bjsovereign
Mar 28, 2017 08:58 AM
MK2
Oct 30, 2016 04:48 PM
blurooster
Oct 16, 2014 09:21 PM
