Mrk 1 over-engine silencer replacement
Old Mar 23, 2025 | 06:44 PM
jrosenfeld's Avatar
Default Mrk 1 over-engine silencer replacement
Some time ago I asked for ideas about replacing the ugly silencer that hides the engine of the Mark 1. I came up with a solution.
Steel tube replacing silncer and shined up the cam shaft covers, carburetor pots, air intake manifolk and radiator cap. Real bling now.
Old Mar 23, 2025 | 07:39 PM
Jose's Avatar
I understand the original "silencer" is an Air Filter, with an actual paper filter inside. Not exactly a work of beautiful art, but effective.
The same one fitted to the S type from 1963 to 1968.
Old Mar 24, 2025 | 05:48 AM
Peter3442's Avatar
Congratulations! It looks very good.
Jose, I forget the details, but on some early cars, the box on top of the engine is a silencer without a filter inside. They had an oil bath filter in the LH front wing. See the SNG link below.
https://www.sngbarratt.com/English/#...ds=%5B17191%5D
Old Mar 24, 2025 | 07:40 AM
Jose's Avatar
Peter that must be a messy one to deal with.
Old Mar 24, 2025 | 08:39 PM
jerry_hoback's Avatar
That looks really sharp. What are you using for a filter?
Old May 26, 2025 | 05:40 AM
AussieMark1's Avatar
On 3.4 Mk1s, it is just a silencer, the air filter is an oil-bath unit mounted under the passenger-side wing. The silencer cannot be opened and it doesn't hold a filter.
Old May 26, 2025 | 09:13 AM
hueyhoolihan's Avatar
like many others, i replaced the entire assembly with a couple of pancake style air cleaners that attach directly to the carbs. no re-tuning necessary in my case. full access to the carbs now. lovely!
and some day i may even removed that ugly mounting bracket it was attached to.
Old May 30, 2025 | 01:46 PM
Egreg's Avatar
does this change toe horsepower, or the air to fuel ratio? i would think a mod to the intake would change that...?
Taurox
Jul 16, 2023 02:57 PM
cpq100
Sep 28, 2022 11:34 AM
iramphal
Aug 7, 2022 10:30 AM
Jan Meiling
Nov 13, 2021 05:09 AM
Muti007
Mar 17, 2015 07:46 AM
