progress on MK2
Old Sep 26, 2014 | 08:45 AM
blurooster's Avatar
Default progress on MK2
I have almost finished under the bonnet work and am refitting pieces. The engine is finished and the trans just needs a check up. The rear end has been delivered and cleaned ready for the MK2 brackets. Wiring will be re done with more than two fuses(?) and relays for hi draw items.
Old Sep 29, 2014 | 09:38 AM
primaz's Avatar
Blurooster you need to post some pictures
Old Sep 29, 2014 | 01:23 PM
blurooster's Avatar
Default pics
I am too dumb to post here....... they are in my albums. I will post there until I get smart enough to upload here.
Love your stuff by the way, I have 12 engines on stands and not one LS, Ford Chevy, Cadillac and some are strokers. I will get a deal (near free).on an LS some day
Old Sep 30, 2014 | 07:44 AM
blurooster's Avatar
Default OK I got it
figured out how to post a pic here
This was a trial fitment, but it is getting there.
Old Sep 30, 2014 | 07:48 AM
blurooster's Avatar
see if this works
Attached Thumbnails progress on MK2-imag2148.jpg   progress on MK2-13-l-55802ab9-2075341-1280-100.jpg   progress on MK2-13-80062f4c-458490-1280-100.jpg
Old Oct 1, 2014 | 03:16 AM
Stoney85's Avatar
Have you trial fitted the chev yet? whats it like for clearance?
Old Oct 1, 2014 | 07:56 AM
blurooster's Avatar
I see no problems, if you use stock old rams horns or tight fit headers. A GOOD exhaust guy will have no problems, a r&r guy will whine a lot. The front motor plate sets across the frame rail. The back of a Chevy block is 17" wide so the mid mount is shorter.
Attached Thumbnails progress on MK2-12-ae11057c-2115044-1280-100.jpg   progress on MK2-12-afc5de1b-1948894-1280-100.jpg   progress on MK2-imag2148.jpg
Old Oct 1, 2014 | 09:32 AM
blurooster's Avatar
Just couldn't put an orange motor in the Jaguar
Attached Thumbnails progress on MK2-10686783_10203537842740470_316062333772876040_n.jpg
Old Oct 1, 2014 | 09:34 AM
primaz's Avatar
FYI,
if you opt to put AC like the RetroAir, etc. the air handler will take up the entire space and then some of where the stock battery is located. People either mount the battery in the trunk or in my case I made custom mounts and mounted three batteries under the rear wheel wells where my gas tanks used to be....
Old Oct 2, 2014 | 08:43 AM
blurooster's Avatar
I saw the installation, I am considering a boot mounted a/c system for the wife. She doesn't like air blowing on her face so a package tray vent would suit her.
Old Oct 9, 2014 | 10:35 PM
blurooster's Avatar
Engine is in, tight fit, but in. Pictures when I get back to my desk top. I had to make some adjustments but nothing serious. I may have to bite the bullet and get some coated headers to protect my engine bay paint and make some heat shields and insulate.
Old Oct 11, 2014 | 08:42 PM
blurooster's Avatar
Lowered the sway bar and measured for urethane bushings.
Sourced a 32 Ford aluminum radiator for $150. Only minimum
mods to car.
Old Oct 17, 2014 | 09:09 PM
blurooster's Avatar
Radiator is mounted and a little more pretty work and I am done.
It was for a big block Chevy in a 32 Ford so it should cool.
Transmission cooler mounted also.
Old Oct 21, 2014 | 09:18 AM
blurooster's Avatar
more build pics
Attached Thumbnails progress on MK2-radiator-1.jpg   progress on MK2-vacuum-tank.jpg
Old Oct 21, 2014 | 06:09 PM
MK2's Avatar
MK2
Default Progress on MK2
Looking great. Love the images... More, more more!
Lin
Old Oct 21, 2014 | 10:06 PM
lickahotskillet's Avatar
Blurooster,
Excellent work. Devil is in the details. More pictures of your final engine mounting (front and rear) & exhaust!
Old Oct 22, 2014 | 06:30 AM
blurooster's Avatar
Sanderson tight fit headers will be used but are $$$, gathering up sheckles for that purchase. Probably use 2.5" from collectors and maybe long glass pack mufflers? Not a lot of MK2 owners in town to get rid of these extra parts to finance the new stuff. picture of modified xj shifter for 700r4 and modified booster to eliminate pricey hose.
Attached Thumbnails progress on MK2-imag2203.jpg   progress on MK2-imag1905_1.jpg
Old Oct 22, 2014 | 08:22 AM
Alphatrev's Avatar
Nice underhood shots. I can't help looking at it and thinking there is room to move that V8 back about 6 inches without too much cutting. Not suggesting you should have done it, but I want to.
Old Oct 22, 2014 | 12:35 PM
blurooster's Avatar
foot boxes would have to be cut and gas pedal moved. I am not sure about trans clearance(jag is small). I did mine this way because I really didn't want to cut up the floor since upholstery is fair. The only real advantage would be weight distribution and since I am already much lighter than the Jag I felt it would be a lot of work and little or no gain.
aluminum heads, manifold, radiator and pump. plus headers
Old Oct 23, 2014 | 12:21 AM
Stoney85's Avatar
Looks like a nice fit in there.
Great find on the radiator too!
