02 S-Type ABS fault
Old Jan 31, 2014 | 09:25 AM
Jagst02's Avatar
Exclamation 02 S-Type ABS fault
Hello every one, this is my first Jaguar, i have a 2002 S-type, i love that car it is just amazing, now my problem is this:
the car wasn't shifting right, i read some of this forums and i realize that it could be the speed sensor since the dashboard reads "Traction Control Fault" i checked all sensors and the front right wheel was disconnected or unplugged, i cleaned it all and put it in place, and it worked good, the Traction control was active again and the car shifted perfectly, however when i break it makes a loud sound as if the ABS was engaged, i went and remove the ABS motor fuse in the fuse box under the hood ( square pink one ) and it solve the problem, my concern is that the break and ABS light are one, its any way to bypass this or fix the abs or is it definitely something wrong with the sensor ??
Old Jan 31, 2014 | 10:29 AM
Welcome to the forum Jagst02,
I've copied your TC fault issue to the S-Type tech forum for advice from members with the same model. Here's a direct link to it:
https://www.jaguarforums.com/forum/s...-fault-110928/
Follow this link S-Type / S type R Supercharged V8 - Jaguar Forums - Jaguar Enthusiasts Forum to the main S-Type forum for help, advice and information.
You can also visit the US Lower Atlantic Region forum by following this link https://www.jaguarforums.com/forum/l...c-sc-fl-ga-66/
Enjoy the forums.
Old Jan 31, 2014 | 02:45 PM
Welcome to Jaguar Forums jagst02,
__________________
Old Jan 31, 2014 | 04:35 PM
welcome to the forum - plenty of info and support simply follow the links Graham has provided - enjoy!
Old Feb 1, 2014 | 07:38 PM
search facility etc, can be found here within the following link Helpful_information
ericjansen
Dec 19, 2021 12:20 AM
picard
Oct 12, 2015 11:56 AM
flyrr100
Sep 29, 2015 03:47 PM
xjrjag
Sep 24, 2015 10:08 PM
John Fox
Sep 19, 2015 07:56 PM
