1967 Mark 2 running hot
Old Jul 10, 2019 | 10:25 AM
stephenggreen's Avatar
Default 1967 Mark 2 running hot
I own a Mark 2 , 1967 3.4 Jaguar which is running hot
I have changed the thermostat, coolant and added water wetter to the rad, I have also added lead addative to the fuel and it runs just above the 90 degrees on the thermometer - any suggestions?
Old Jul 10, 2019 | 10:41 AM
S-Type Owner's Avatar
Welcome. I would suggest that you take your inquiry to the appropriate technical forum, which is located here:
https://www.jaguarforums.com/forum/m...40-daimler-61/
The members of the above forum are pretty sharp and it is an active forum;
Old Jul 10, 2019 | 11:57 AM
67ECoupe's Avatar
Assuming your "just above the 90 degrees on the thermometer" is your car's factory supplied gauge, which is calibrated in Degrees Celsius, and you are in U.S., that temperature reading sounds normal for a typical Jaguar's temperate climate designed cooling system this time of the year.
From my experience from owning one, Jaguar would calibrate their '67 XKE's electric cooling fans' "otter switch" to not kick the fan on until just over 100 deg C!
If you are in the UK, your current temp indicates 71 deg F, which is warm enough to warrant your car's thermostat opening which would look like it is doing its job.
So unless you are getting other symptoms of overheating, or until it starts going over 100 on your gauge, I would not worry about it.
Old Jul 10, 2019 | 03:34 PM
Hello,
Old Jul 10, 2019 | 03:52 PM
Daf11e's Avatar
Welcome aboard.
Old Jul 10, 2019 | 05:37 PM
Welcome to the forums Stephen,
Follow this link https://www.jaguarforums.com/forum/m...40-daimler-61/ to the MKI / MKII S type 240 340 & Daimler forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues.
You can also uset the UK & Eire Region forum by following this link https://www.jaguarforums.com/forum/uk-eire-68/ to find other members in your region.
Enjoy the forums.
Old Jul 10, 2019 | 09:15 PM
Welcome to the Forums.
Old Jul 11, 2019 | 03:33 AM
Thanks for that - I'll just keep an eye on it then
Old Jul 11, 2019 | 05:24 AM
o1xjr's Avatar
Welcome to the forums.
Old Jul 11, 2019 | 05:30 AM
Welcome to Jaguar Forums Stephen,
Old Jul 11, 2019 | 08:01 AM
justV12
Mark V - X 420G
53
Oct 6, 2025 09:47 PM
jaquarmb
E type ( XK-E )
Apr 16, 2016 09:34 AM
kevo
Sep 8, 2015 09:45 AM
PEM24
Jul 31, 2013 07:56 AM
jaguarmike
May 28, 2008 06:32 PM
