1997 xj6L no heat!
Old Mar 6, 2021 | 07:36 PM
kader's Avatar
Default 1997 xj6L no heat!
been trying to fix my heat for a few weeks now after buying a 1997 xj6L, it is winter here and the car will only blow cold air (close to what temperature the air is outside), the inlet hose going to my heater core gets warm after turning the heat on max however the outlet hose going to my pump is neither hot or cold. the guy told me the in cabin air sensor was broken however when i put heat to it the ohms began to drop which i believe is what you want to happen, i replaced the thermostat, began to flush my heater core which came out looking like brand new coolant so i stopped the flush, checked the brushes inside the heater pump which looked perfectly fine, however when i have the heat on i cannot feel or hear buzzing coming from said pump, my ambient air temp sensor reads a few degrees warmer than the actual temperature, and my coolant level fluctuates a ton before i start my car and while it is running (sometimes itll be below the min line, other times it will be right below the max). if anyone has any idea of something else i can try that would be greatly appreciated, thanks in advance!
Old Mar 7, 2021 | 06:04 AM
Welcome to the forums kader,
When you have eliminated coolant flow issues as the possible cause, sticking flaps in the AC/Heater unit is the next one to investigate. Failed servo motors can leave them closed so there's no heat output.
Follow this link https://www.jaguarforums.com/forum/xj-xj6-xjr6-x300-26/ to the X300 forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues. You can also use the Canada Region forum by following this link https://www.jaguarforums.com/forum/canada-73/ to find other members in your region.
Enjoy the forums.
Old Mar 7, 2021 | 06:56 AM
Welcome to the Forums.
I will only say, mine had similar, not as cold as you are, but the filler pressure cap was dud, that sorted it.
As Graham said, more in the Tech Section.
Good luck.
Old Mar 7, 2021 | 06:59 AM
welcome to the forum
Old Mar 7, 2021 | 07:24 AM
Welcome to Jaguar Forums kader,
Old Mar 7, 2021 | 08:21 AM
Hello,
I'll bet you want heat in Alberta! I hope you get this fixed soon.
Old Mar 7, 2021 | 09:37 AM
kader's Avatar
awesome, thanks Graham, ill give that a shot.
Old Mar 7, 2021 | 03:24 PM
Daf11e's Avatar
Welcome aboard.
Old Mar 8, 2021 | 12:30 AM
o1xjr's Avatar
Welcome to the forums.
Old Jan 29, 2022 | 01:27 PM
kader's Avatar
Hey Graham, sorry for such a late reply. I ended up replacing both the servo motors located on the drivers (LHD) side of the HVAC unit. No difference in air temp output. Been trying to find out if there are more than those two servo motors on my car but can't find any info. If you know the correct number of blend door actuators my car has (1997 xj6L) that would awesome. Also curious, even though my in car temp sensor reads correct ohms for the heat applied could it be a possibility that it is somehow telling my HVAC unit that the cabin is at the correct temp? And if so how would a guy go about fixing that? Thanks again.
Kade
Old Jan 29, 2022 | 05:48 PM
Kade,
You should be able to feel the pump working - it vibrates gently.
There's three temperature sensors involved (see items 1, 3 and 5):
If you have replaced the servo motors, I'd begin to suspect the control module (item 2):
Best posting questions in X300 forum for advice from members currently running this model. I'm on the fifth Jaguar since I sold mine.
motogirl_94518
Jun 12, 2012 01:56 PM
AJ16er
Jan 22, 2010 10:37 PM
Tpanchot
Dec 17, 2009 09:13 AM
legalian
Mar 14, 2008 09:37 AM
