1998 Jaguar XJ8 L - Need a Solution
Old Jan 2, 2020 | 11:21 AM
DaddyBill3's Avatar
Unhappy 1998 Jaguar XJ8 L - Need a Solution
I have a 1998 Jaguar XJ8 L. the car won't crank – the battery was tested and is fine (70%). The car is getting fuel in the line, the belts are turning, starter is good, but it just does not turn over after trying for 10 minutes.
I discovered what appears to be red transmission fluid under the front of the vehicle. What could be the problem?
Old Jan 2, 2020 | 11:24 AM
NBCat's Avatar
What is the voltage across the battery terminals when checked with a voltmeter?
Old Jan 2, 2020 | 11:25 AM
DaddyBill3's Avatar
11.9 v
Old Jan 2, 2020 | 11:36 AM
NBCat's Avatar
Charge the battery at 2 to 5 amps for 8 hours and retest. Battery should show a minimum of 12.6 volts after load test for 10 seconds or should be replaced.
The fuel pump and other systems may not run correctly with a battery having less than 12 volts.
Old Jan 2, 2020 | 01:24 PM
Welcome to the forums DaddyBill3,
I've moved your other version of this question from US Mid Atlantic Region to X308 forum for advice from members with the same model. Here's the direct link to it:
https://www.jaguarforums.com/forum/x...needed-227413/
Follow this link https://www.jaguarforums.com/forum/xj-xj8-xjr-x308-27/ to the main X308 forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues.
Enjoy the forums.
Old Jan 2, 2020 | 01:30 PM
Daf11e's Avatar
Welcome aboard.
Old Jan 2, 2020 | 07:18 PM
Welcome to the Forums.
Old Jan 3, 2020 | 05:15 AM
o1xjr's Avatar
Welcome to the forums.
Old Jan 3, 2020 | 07:35 AM
Old Jan 3, 2020 | 08:43 AM
Welcome to Jaguar Forums DaddyyBill3,
Old Jan 3, 2020 | 10:23 AM
Hello, Bill,
DaddyBill3
Jan 2, 2020 02:21 PM
firstchoice
May 25, 2016 08:30 AM
Ipc838
Aug 26, 2012 01:27 PM
Clement Iyere
Dec 6, 2009 07:00 AM
