1998 XK8 convertible proper jacking
Old Sep 21, 2016 | 02:05 PM
Davecs312's Avatar
Default 1998 XK8 convertible proper jacking
I want to change my transmission fluid in my garage. I have a floor jack and 4 jack stands. What is the preferred way to jack up the car, and place the jack stands under the car?
Thanks,
Dave S.
Old Sep 21, 2016 | 07:05 PM
Hello, Dave,
When I want to jack my car, I put a custom cut square of heavy plywood (5 quarter) on my long floor jack and put it under the center of the IRS, and lift it about 18 inches and put jack stands under the back lift points.
Then I put a motorcycle jack under the front cross member, being CAREFUL TO MISS THE RACK, and jack the front until the car is level and put stands under the front lift points.
If the car isn't as high off the floor as I need I lift the back again, raising the jack stands, and then the front again, also raising the stands, and I keep this up until I have it high enough off the floor that I can crawl under comfortably on a creeper.
However, your car may require completely different procedures, which I'm sure members of our XK8 section can tell you all about. Someone will be along shortly to direct you there.
Old Sep 21, 2016 | 08:42 PM
Daf11e's Avatar
Welcome aboard Dave.
Old Sep 21, 2016 | 09:39 PM
Welcome.
Elinor has covered it.
As for your model specifics, I dont know.
I suggest a re-ask in the XK8/XKR (X100) section.
Old Sep 22, 2016 | 04:27 AM
o1xjr's Avatar
Welcome to the forum
Old Sep 22, 2016 | 05:44 AM
welcome to the forum -
I jack the front using the cross bar under the radiator and place jack stands under jacking points, then on the rear, look in the center and you will see a plate with 4 bolts dead center of the car, - I use this as the jacking point to raise the rear high enough to place jack stands under jacking points
Old Sep 22, 2016 | 10:15 AM
Welcome to the forum Dave,
Follow this link XK8 / XKR ( X100 ) - Jaguar Forums - Jaguar Enthusiasts Forum to the XK8/XKR forum for help, advice and information.
The 'HOW TO' thread at the top is a good place to start for information on regular issues.
You can also visit the US Southwest Region forum by following this link US Southwest - Jaguar Forums - Jaguar Enthusiasts Forum
Enjoy the forums.
Old Sep 22, 2016 | 10:51 AM
Welcome to Jaguar Forums Dave,
Steve has you covered but there is a video
elindo
Apr 10, 2023 07:27 AM
omgimali
Oct 2, 2016 02:07 PM
Mr.Hotrod
XJ40 ( XJ81 )
Sep 21, 2016 09:19 AM
paullap
Sep 20, 2016 02:43 PM
fox5mx101
Sep 19, 2016 01:07 AM
