2000 XJ8 need a little help please.
Old Mar 11, 2014 | 07:52 PM
hminzeberg's Avatar
Default 2000 XJ8 need a little help please.
Hello, I recently purchased a 2000 White / Leather Cream interior XJ8 with 64k for my wife...OMG....One beautiful vehicle. Long story short. She blew a top radiator hose on the interstate and had the smarts enough to pull over and shut the car down immediately. I had personally loaded it on a flat bed and its in my common sense mechanics hands. He has replaced one tensioner and is obviously going to replace the other when he called me and said that #4 cylinder has zero compression, however when he pressurizes it with 130 psi it holds...HELP.....please
Old Mar 11, 2014 | 08:53 PM
MidwestJag's Avatar
Welcome to the forum, hminzeberg:
Sounds like you have a nice car. Easy to say, I suppose, but don't panic. Post your problem in the X308 section and you'll get a number of opinions and suggestions as to how to proceed.
Again, welcome!
Scott
Old Mar 11, 2014 | 09:52 PM
Welcome to Jaguar Forums hminzeberg,
Follow Scott's advice you will find the tech section here XJ ( X308 ) XJ8 / XJR - Jaguar Forums - Jaguar Enthusiasts Forum when you get a chance have a look in the regional section also Lower Atlantic - NC SC FL GA - Jaguar Forums - Jaguar Enthusiasts Forum.
Old Mar 11, 2014 | 10:04 PM
Bad Cattitude's Avatar
Welcome!
Old Mar 11, 2014 | 10:18 PM
Steve8's Avatar
Welcome to the forums hminzeberg. As said above, don't panic, sit tight, and post your questions on the X308 section. There'll be others who will have some good advice for you. For me, I can't reconcile someone saying zero compression on one hand, and then it's OK when "pressurized". Huh? Just think, if it ran OK before the hose blowout, it will most likely still run OK afterwards too if your better half had the common sense to shut it down immediately.
Steve
Old Mar 12, 2014 | 03:28 AM
Welcome to the forum hminzeberg,
Shutting it down straightaway should have prevented anything serious happening and the fact that No4 will hold pressure is looking good.
Follow Norri's link to the X308 forum for help, advice and information.
Enjoy the forums.
Old Mar 12, 2014 | 07:06 AM
welcome to the forum - you will find plenty of info and support here simply follow the links Norri has provided and enjoy!!!
Old Mar 12, 2014 | 11:18 AM
Don B's Avatar
Welcome hminzeberg!
Cheers,
Don
Old Mar 15, 2014 | 09:32 PM
search facility etc, can be found here within the following link Helpful_information
bdboyle
Sep 16, 2019 05:58 PM
Poet
Oct 2, 2015 09:00 AM
Rocky15
Sep 28, 2015 04:59 PM
pino
Sep 26, 2015 08:05 PM
mikin
Sep 26, 2015 10:21 AM
