Came for help with an 88
Old Aug 14, 2019 | 06:39 PM
Hulio Man's Avatar
Default Came for help with an 88
My name is Jason. I have a 88 xjs v12. I got it not running from a guy ready to scrap it.
Current problems, aside from cosmetic
Will only crank of I jump the starter relay.
Fuel pump does not seem to be working. Briefly has a little over 3v when I turn the key on. Just me today so I cannot jump relay and check fuel voltage.
My questions are can you get a different 5 pin relay to work rather than the $70 jag one? That name tag seems a little ridiculous so I was wondering if anyone tried a generic one, as in not made for jag at all just a 5 pin relay that can handle correct volts.
And how many volts are normal at the fuel pump when not cranking just initially energized?
If I hook direct power to it I get a thunk out of it but did not want to try it longer without fuel in it. Also the car will turn and try to run off of ether when the relay is jumped. Just wanted to be sure that jumping it is not why I'm also not getting fuel before I throw money at extra parts
Thanks in advance for any help. The car is in rough condition, that's why I really want it to run before I go spending much more on it
Old Aug 14, 2019 | 11:20 PM
Hello, Jason,
Someone will be along shortly to direct you to our Xjs section where members and Gurus can help you out with your V-12.
Old Aug 14, 2019 | 11:32 PM
Welcome to the Forums.
The XJS Section is where the answers will be.
Read the Stickies I wrote at the top, may have all the answers, and if not, ask away.
Good luck.
Old Aug 14, 2019 | 11:42 PM
Daf11e's Avatar
Welcome aboard Jason.
Old Aug 15, 2019 | 03:32 AM
Welcome to the forums Jason,
Follow this link https://www.jaguarforums.com/forum/xjs-x27-32/ to the XJS forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues.
You can also use the US Lower Atlantic Region forum by following this link https://www.jaguarforums.com/forum/u...r-atlantic-66/ to find other members in your region.
Enjoy the forums.
Old Aug 15, 2019 | 06:51 AM
Welcome to Jaguar Forums Jason,
Old Aug 15, 2019 | 07:19 AM
Old Aug 15, 2019 | 05:25 PM
o1xjr's Avatar
Welcome to the forums.
slowcreek54
Sep 7, 2017 06:27 AM
tazman
Jun 16, 2017 02:08 AM
DeepJag
Aug 11, 2016 01:51 PM
Mlb
Mar 24, 2013 08:32 PM
alicat
Jul 6, 2010 09:20 AM
