Fan Running Unusually Long After Shutting off Vehicle
Old Jul 19, 2018 | 07:26 PM
mlatneysr's Avatar
Default Fan Running Unusually Long After Shutting off Vehicle
Hello Jag Forum Members,
I'm new to the site and after perusing through many of the threads, I am happy I found it.
I have a 2007 Vanden Plas. About a month ago, after driving approximately 8 miles, I noticed the temperature gauge indicating my car was running hot. I immediately pulled over to check the coolant level and other indicators for an overheating engine. Didn't notice anything so I let it sit for about 20 minutes and drove back home (indicator did not increase). When I shut the vehicle off, the fan stayed on much longer than usual (about 5 to 7 minutes)...I assume to cool the engine down. I took the vehicle to the shop the following day and they informed me the temperature gauge is indicating the engine is running hot, but their test showed the engine was, in fact, running strong and in temperature normal range. I drove the car home (about 5 miles) and the gauges were normal. However, again, when I shut the vehicle off the fan stayed on for about 5 minutes. I started the car the next morning and let it idle while closely watching the temperature indicator...It was normal. I drove it for about 4 miles and the indicator stayed in normal range. When I shut if off, the fan stayed on for about 3 to 4 minutes. I've been told the problem could possibly be the coolant temperature sensor. I have a ASE certified mechanic coming this weekend, however, I wanted to see if anyone has experienced this problem? If so, can you please advise as to how you solved it.
Thanks for you help in advance!
Old Jul 20, 2018 | 02:20 AM
Welcome to the forum mlatneysr,
You should certainly take any indication of overheating very seriously. Water pump and thermostat are possible culprits; checking for error codes will help identify a problem with the ECT sensor.
It sounds like you have already found the relevant model froum but if not, follow this link XJ XJ8 / XJR ( X308 ) - Jaguar Forums - Jaguar Enthusiasts Forum to the X350 forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues.
You can also visit the US Central Region forum by following this link https://www.jaguarforums.com/forum/us-central-36/ to find other members in your region.
Enjoy the forums.
Old Jul 20, 2018 | 02:27 AM
Daf11e's Avatar
Welcome aboard.
Old Jul 20, 2018 | 05:28 AM
Welcome to Jaguar Forums mlatneysr,
Old Jul 20, 2018 | 05:52 AM
o1xjr's Avatar
Welcome to the forums.
Old Jul 20, 2018 | 05:58 AM
Welcome to the Forums.
Old Jul 20, 2018 | 09:26 AM
Old Jul 20, 2018 | 03:43 PM
Hello,
mhamilton
19
Feb 7, 2020 03:43 AM
lisalauck
XF (X260)
Mar 3, 2016 06:19 PM
spthrift
Oct 5, 2014 05:17 AM
eastorlando
Apr 11, 2008 07:52 PM
happilute
Sep 30, 2007 05:48 PM
