Front Suspension Problems
Old Jul 21, 2018 | 07:33 PM
emadkomar1's Avatar
Default Front Suspension Problems
I'm a new member, have 2011 Jaguar XJL 5.0 Supercharged and issues with rattling sounds coming from both side of the front wheels location. I have changed the struts twince thinking they might be bad, changed u-joint ball and changed the front lower control arms and still have the rattling sounds. Don't know else it could be, but need help. Thanks
Old Jul 21, 2018 | 07:42 PM
o1xjr's Avatar
Welcome to the forums.
Old Jul 21, 2018 | 08:29 PM
If you already changed the front axles then I have no idea.
But they will rattle and click, especially when going round corners.
I hope you find the solution.
Old Jul 21, 2018 | 09:17 PM
Kenika65's Avatar
I would say after all of your time and money spent replacing said parts it would be worth having someone that has experience diagnose the issue at a cost much lower that you have already spent on the said issue.
Best and worst part of a forum is an update so please update us after you figure out the issue!
Old Jul 22, 2018 | 03:33 AM
Welcome.
Most "rattles" are linked to the sway bar, and its links and mount bushes.
Good luck
Old Jul 22, 2018 | 04:36 AM
Daf11e's Avatar
Welcome aboard.
Old Jul 22, 2018 | 05:39 AM
Robman25's Avatar
+1 on the ARB link pins/bushes.
Old Jul 22, 2018 | 06:38 AM
Welcome to the forum emadkomar01,
Throwing parts at a Jaguar soon costs a lot of money and is not an efficient method of troubleshooting. I've had rattles on various Jaguars which have been from worn suspension bushes, failed damper mounts, loose brake backing plates, failing Cats, and broken heat shields. A Jaguar dealer or Independent Specialist would diagnose the cause and quote for repairs. Once you know exactly what is causing the rattle you can then decide how to proceed.
I know you've already found your way to the X351 forum with the same question so there's no need for a link to it from me.
You can also visit the US Western Region forum by following this link https://www.jaguarforums.com/forum/western-us-ak-ca-nv-ut-hi-wa-id-38/
Enjoy the forums.
Old Jul 22, 2018 | 07:54 AM
Old Jul 22, 2018 | 08:20 AM
Welcome to Jaguar Forums emadkomar01,
milleniumaire
Oct 1, 2020 05:59 PM
Gregfromuk
Oct 7, 2013 03:03 PM
Jayshmie07
Jul 8, 2012 04:24 PM
MANIACK
May 30, 2012 09:06 AM
jaguarNeWb
Dec 1, 2010 09:42 PM
