Grinding rubbing sound
Old Sep 9, 2018 | 04:40 PM
Andi2610's Avatar
Default Grinding rubbing sound
Tonight after a 30 mile drive home I noticed a grinding sound while turning left on an island and the when I turned left to wards home. this has only just started there is no sound when at speed or turning right. There is no vibration through the floor or peddles and no pulling to the right or left.
the noise sounds like its coming from the left rear but I cannot be be totally sure.
Does any one have any idea what this could be.
Old Sep 9, 2018 | 09:05 PM
Ooo! That does Not sound good!
But it's hard to know what it might be without knowing what car. If we knew that, someone could direct you to the correct section where members familiar with that model can help you get to the bottom of it all.
Old Sep 10, 2018 | 12:04 AM
Daf11e's Avatar
Welcome aboard.
Old Sep 10, 2018 | 01:29 AM
Welcome to the forum Andi2610,
A post in the
New Member Area - Intro a MUST forum is an opportunity for you to tell us about yourself and YOUR VEHICLE. Other than it is likely to be a Jaguar, you have given no hint of Model or Year either here or in your profile .......
Old Sep 10, 2018 | 01:42 AM
Andi2610's Avatar
Old Sep 10, 2018 | 01:44 AM
Andi2610's Avatar
Jaguar XF 3.0 diesel
Old Sep 10, 2018 | 02:20 AM
That's more like it!
Grinding noises are usually brake related (worn pads or sticking caliper) but as it only happens when turning left, it could be a suspension issue. Identifying the precise location of such a sound is notoriously difficult for a driver and it often helps to have a passenger who is able to move and turn their head to trace it. In any event, it is likely to be a potential safety issue and needs prompt investigation. This will certainly involve having the vehicle jacked up and the wheels removed to check brakes and suspension.
If your XF is the 2007 - 2015 model, follow this https://www.jaguarforums.com/forum/xf-xfr-x250-44/ link to the X250 forum for help, advice and information. If it's the current 2015 onwards model, follow this link https://www.jaguarforums.com/forum/xf-x260-99/ to the X260 forum.
You can also visit the UK & Eire Region forum by following this link
https://www.jaguarforums.com/forum/uk-eire-68/ to find other members in your region.
Enjoy the forums.
Old Sep 10, 2018 | 02:35 AM
Andi2610's Avatar
Its a Jaguar XF 3 Ltr V6
i was thinking suspension but
I never had any suspension
Act in this way without indicators
Old Sep 10, 2018 | 03:01 AM
It's all speculation until you pinpoint the corner and get the road wheel off to inspect wishbones, vertical links, hubs and brakes.
Old Sep 10, 2018 | 04:55 AM
o1xjr's Avatar
Welcome to the forums.
Old Sep 10, 2018 | 05:29 AM
Welcome to Jaguar Forums Andi2610,
Old Sep 10, 2018 | 06:16 AM
welcome to the forum
cwf95gsx
Jun 10, 2018 03:32 AM
liquidreality
Aug 20, 2014 08:21 PM
jockmahogis
16
Nov 29, 2013 04:40 AM
tc80211
May 4, 2010 10:51 AM
kenzed
Nov 3, 2007 03:48 PM
