Heater blows cold air
Old Mar 17, 2012 | 11:22 PM
jag-pilot's Avatar
Exclamation Heater blows cold air
Just bought 2002 jaguar s-type 68k that has few issues.
For some reason heater blows cold/warm air when heater settings set to max temperature. In the same time engine temperature stays in the middle.
Can u help me figure out what is wrong with my jag and how I could fix that.
Old Mar 17, 2012 | 11:32 PM
QuartzSTypeR's Avatar
First you should check your coolant level. Also please fill out your info so we know what motor your car has.
Old Mar 17, 2012 | 11:46 PM
jag-pilot's Avatar
V6 and I already flush the system using instructions in forum
Old Mar 18, 2012 | 01:01 AM
Was this a problem before the flush? You could have an air pocket trapped in the system and might need to bleed it.
Old Mar 18, 2012 | 07:09 AM
joycesjag's Avatar
Welcome to the forum jag-pilot.
Congrats on your new S Type. There is loads of information in the S Type FAQ Thread. BTW you have a common problem, a search will help you. Please post any technical questions in he appropriate area.
Enjoy all the site has to offer!
Old Mar 18, 2012 | 10:16 AM
jag-pilot's Avatar
lady that sold Jag to me said that her mechanic checked the car and he said that she need to replace water pump. i check water pump was working fine. BTW while i was troubleshooting cooling system i discovered that thermostat was missing and expansion tank was leaking. So i got whose things replaced and i flushed the system.
interesting part is that on cross-pipe release plug cooling is hot but on the heater release plug is warm.
Old Mar 18, 2012 | 12:34 PM
joycesjag's Avatar
jag-pilot, again I will ask that you post all technical questions and fixes in their appropriate section.
I moved your last post to the S Type section, as this is the introduction section.
Thank you
Old Mar 18, 2012 | 01:41 PM
Welcome to the forum,
Old Mar 18, 2012 | 08:51 PM
welcome to Jaguarforums, good to have you here with us
so jump on in and enjoy
Old Mar 19, 2012 | 01:06 PM
K.Westra's Avatar
Welcome
02jagstype
23
Oct 23, 2022 07:03 PM
tonyforman
Sep 10, 2015 07:23 PM
OkieTim
Sep 8, 2015 04:48 PM
tberg
Sep 7, 2015 07:32 AM
Corycarlo
Sep 5, 2015 11:41 AM
