Installing a hidden antenna
Old Sep 15, 2020 | 08:24 PM
JustinV's Avatar
Default Installing a hidden antenna
Hi there, new to Jag ownership, new to the forum. I purchased the car about a month ago. Some of the expected things to not work well after 34 years don’t and I am working to fix them. First successful repair was the installation of a new gas tank selector switch. The antenna mast was not working when I bought the car. The mast is junk and after taking apart the rear tail and inspecting the antenna motor in the trunk I can say that system is just not going to work and finding a replacement is not easy. I unhooked the power to the motor as it would just make really loud noises. I thought a simple solution would be a hidden antenna since the antenna cable is right in the trunk. I would like to put the hidden antenna in the back window. He antenna also requires power, is there anything in the trunk behind the rear seat that I could splice into to power the antenna? I am a novice and learning as I go. Would be grateful for any help!
Old Sep 15, 2020 | 09:25 PM
Welcome to the Forums.
I suggest adding your car details to your Sig, via the CP tab, so others know you have a Series 3 car. The tank selection switch triggered me.
The members in the XJ6/12 Series 1,2,3 Tech Section will know.
Good luck.
Old Sep 16, 2020 | 02:25 AM
Welcome to the forums JustinV,
Follow this link https://www.jaguarforums.com/forum/x...s-i-ii-iii-16/ to the XJ6 & XJ12 Series I, II & III forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues. You can also use the US Northeast Region forum by following this link https://www.jaguarforums.com/forum/us-northeast-35/ to find other members in your region.
I've added vehicle details to your Signature to help others to give relevant advice. If you want to change these, go to the User CP button on the left of the top menu bar, then Settings & Options under Your Control Panel. Select Edit Signature and enter the details.
Enjoy the forums.
Old Sep 16, 2020 | 02:54 AM
o1xjr's Avatar
Welcome to the forums.
Old Sep 16, 2020 | 03:54 AM
Welcome to Jaguar Forums JustinV,
Old Sep 16, 2020 | 04:47 AM
Daf11e's Avatar
Welcome aboard Justin.
Old Sep 16, 2020 | 09:07 AM
Hello,
Old Sep 16, 2020 | 03:18 PM
Roger Mabry
Jan 2, 2014 06:51 PM
ukester
Jul 26, 2013 07:30 AM
ukester
May 30, 2013 06:28 AM
mrtalkradio
Feb 10, 2011 06:46 AM
