New to Jags but not to working on vehicles
Old Jan 19, 2019 | 05:43 PM
Richard Maxwell's Avatar
Default New to Jags but not to working on vehicles
Hello. I'm new to Jags, but fairly knowledgeable to working on vehicles. I'm a little stumped on this one however. I have an 07 Jag S type 3.0 that I recently purchased. Test drive went fine. Took for long enough to get to running temp while doing low and high load. No hesitation, no lights, slight burning smell (guy recently replaced both cats), and was very nice overall. Wasn't driven between test drive and purchase (just couple days). He also had put new battery in it. Wasn't much gas, so put enough to get home (drive that took about 55 miles). Drive went fine. Sat couple days. Drove around for some errands and filled tank. Drove fine till after filled up. Started hesitating by time got home (about 5 miles) and started flashing engine light and another yellow light with info saying "restricted performance". I've limited running it to try to diagnose it. OBDII gives 2 codes. One is misfire cylinder 5 (P0305) and other is misfire on start up under 1k rpm (forgot number). I've added "Heet" with injector cleaner in case had moisture from sitting, anti ethanol additive, and octane booster (since calls for 91 or higher octane, but filled with 89 octane). Has yet to run right. Lights and message will go off after erase codes and will stay off, come on when try accelerate, go off while steady speed, not come on when restart, and come on when restart. The only sure thing is that the engine light will come on and the other light, and message, comes and goes. I have tools but no "shop" tools/instruments. Sorry for the long post... Please help!
Old Jan 19, 2019 | 06:13 PM
Welcome.
That question etc should be asked in teh S Type Tech Section. MANY more members will see it and respond, as only a few members come in here.
My "guess" is that since it happened after fuel top up, is the fuel cap seated correctly, coz that WILL bring on the check engine light.
Battery, I know it NEW, but is of teh correct spec, and oomph, these cars a juice hungry, and a dud?? battery will reek havoc.
Good luck.
Old Jan 19, 2019 | 06:41 PM
Daf11e's Avatar
Welcome aboard.
Old Jan 19, 2019 | 06:51 PM
Welcome to the forum Richard,
My first suspect would be the "new" battery but until you have the codes read, it's all going to be speculation.
Follow this link
https://www.jaguarforums.com/forum/s...ed-v8-x200-15/ to the S-Type forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues.
Enjoy the forums.
Old Jan 19, 2019 | 07:01 PM
Originally Posted by Grant Francis
Welcome.
Good luck.
Yes it was seated correctly and tightened correctly. Battery was checked and is correct specs and is fully charged, no recharging issues, and no dead or dying cells. I'll post in the other forum, ty.
Old Jan 19, 2019 | 09:40 PM
Hello, Richard,
As you have discovered, Jaguars are a bit temperamental about some things. That's because, of all cars on the road today, they have a quality of Soul. Get on its good side, it will run nearly forever. Get on its bad side, and ownership will merely Seem like forever.
Old Jan 20, 2019 | 03:32 AM
o1xjr's Avatar
Welcome to the forums.
Old Jan 20, 2019 | 08:22 AM
Welcome to Jaguar Forums Richard,
Old Jan 20, 2019 | 08:37 AM
Old Jan 20, 2019 | 08:42 AM
S-Type Owner's Avatar
From one S-type owner to another... Welcome. The S-type forum is populated with a very friendly group and contains a wealth of knowledge. Enjoy!
Jaggernaut3
May 8, 2019 12:06 PM
Arthur DeRoss
Jun 11, 2018 08:21 AM
Gunney8
Feb 14, 2017 09:57 AM
Mark in Maine
Feb 11, 2015 07:25 PM
glenn's E
Jul 24, 2014 07:44 PM
