No oil pressure on start
Old Jun 9, 2023 | 05:49 PM
LaggyJaggy's Avatar
Default No oil pressure on start
Long story short 3 of my spark plugs had hella oil on them so I took off and replaced the valve gaskets n o rings. Since I did that I also jus did an oil change and replaced the oil filter. Now my oil pressure gauge reads at zero and the oil light is on.
There are no visible leaks anywhere around the gasket nor are there any leaks around the oil filter. I used the same oil as before so idk what’s going on please help
Old Jun 9, 2023 | 05:51 PM
LaggyJaggy's Avatar
Default Adding on to previous post
I forgot to say I also replaced all the spark plugs and ignition coils because it was all pretty old
Old Jun 9, 2023 | 06:50 PM
Daf11e's Avatar
Welcome aboard.
Old Jun 9, 2023 | 08:17 PM
S-Type Owner's Avatar
OP: You might want to let us know which model and engine you are experiencing this issue with...
Old Jun 9, 2023 | 10:12 PM
Welcome to the Forums.
Your profile lists a 1996 XJ6, so the XJ6/XJR6 (X300) Tech Section is the place for tech questions.
This is the Intro area, not for Tech Questions.
Good luck.
Old Jun 10, 2023 | 12:50 PM
Welcome to the forums LaggyJaggy,
I can see you've already found your way to the X300 forum with this question so there's no need for a link to it from me. The 'HOW TO' thread at the top is a good place to start for information on regular issues. You can also use the US Western Region forum by following this link https://www.jaguarforums.com/forum/western-us-ak-ca-nv-ut-hi-wa-id-38/ to find other members in your region.
Enjoy the forums.
Old Jun 10, 2023 | 05:40 PM
Welcome to Jaguar Forums LaggyJaggy,
Enjoy the forum..
Old Jun 11, 2023 | 06:27 AM
Old Jun 11, 2023 | 09:09 AM
Hello,
Old Dec 5, 2023 | 02:52 AM
ForTheLoveOfCars's Avatar
Good luck.
im guilty of this too lol thank you grant
