Only one passenger door not locking
Old Mar 20, 2021 | 09:13 AM
ajames67's Avatar
Default Only one passenger door not locking
Hello All from the UK.
I suspect I know the answer to this issue but thought I'd just throw it out there in case I am wrong! - So I have a lovely FX 2009 6V 3litre and I am dead proud of it. It is almost perfect apart from the near side rear passenger door does not lock using the central locking. IT DOES UNLOCK. Also if I keep the unlock button on the fob pushed down, it unlocks and all the windows open (as they should) BUT! When I keep the LOCK button down on the fob not only does this door not lock , THE window DOESN'T go up (as it should)
I have had a good look at the lock mechanism and connections and all look good and lubricated. Last comment - The lock/unlock button on the door DOES manually do it's job
Going to replace the ECU
All thoughts helpful
Old Mar 20, 2021 | 02:51 PM
Welcome to Jaguar Forums ajames67,
Old Mar 20, 2021 | 03:36 PM
Daf11e's Avatar
Welcome aboard.
Old Mar 20, 2021 | 03:54 PM
welcome to the forum - enjoy!!!!
Old Mar 20, 2021 | 06:25 PM
Welcome to the forums Alan,
The number one cause of this problem is a failed microswitch in the door latch.
Follow this link https://www.jaguarforums.com/forum/xf-xfr-x250-44/ to the X250 forum for help, advice and information. You can also use the UK & Eire Region forum by following this link https://www.jaguarforums.com/forum/uk-eire-68/ to find other members in your region.
Enjoy the forums.
Old Mar 20, 2021 | 10:04 PM
Hello,
Reluctant door locks can be a giant pain. I hope you find the answer in the section where Graham has directed you.
Old Mar 20, 2021 | 10:57 PM
Welcome to the Forums.
I am with Graham here. ECU's rarely fail, but the device that "tells" the ECU what to do is another factor.
Good luck.
Old Mar 21, 2021 | 01:49 AM
o1xjr's Avatar
Welcome to the forums.
NMW
Mar 16, 2023 08:13 AM
Docko
Jan 9, 2021 06:10 PM
1992JaguarXJSV12
Oct 14, 2018 09:56 AM
