Pete
Old Feb 3, 2022 | 08:23 PM
Jagpug's Avatar
Default Pete
Hi, own a Jaguar S type 3ltr 2005 build, 2006 compliance. 134k
Going nuts over LTFT and STFT as OBD2 reader was purchased as Jaguar /Rover specific and full compliance on most after 2005.
Trouble is OBD2 reads in % and at this time showing bank 1 @119% Long Term and short term @124% bank 2 @ 121% Long term and 128% @short which means what?
Now I understand the concept + fuel - fuel, either side of 0 or GMH either side of -128 + also percentage with 0 being spot on 14.7/1 BUT what F are mine telling me??
Yes I know the threads here are many however plenty of speculation but no answer to my question {which I'm now putting to you} but what the f is mine telling me?
IT could be the reader however it's new it could be a new way of expressing trims I don't know. I do know that there is an air leak in bank 2 or left and the fault always sets in a trailing throttle when you would expect more vacuum to be present suggesting I am right .
I have replaced all upper O rings inlet etc checked all lines for cracks etc even the canister is ok. MAF ok throttle body good .
About to change all plugs to NGK platinum all coils to NTK two new O2 Lambda ie upstream. in the hope, it's not a slight miss on trailing throttle etc. And because I will know where everything stands.
HELP!
Old Feb 3, 2022 | 11:27 PM
Daf11e's Avatar
Welcome aboard Pete, a moderator will be along shortly with some helpful links to get you sorted. I’ve added you to the NSW Roll just follow the link below….good luck!
Old Feb 4, 2022 | 02:19 AM
Welcome to the forums Pete,
I've copied your question to S-Type forum for advice from members with the same model. Here's the direct link to it:
https://www.jaguarforums.com/forum/s...s-help-255897/
Follow this link https://www.jaguarforums.com/forum/s...ed-v8-x200-15/ to the main S-Type forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues.
Enjoy the forums.
Old Feb 4, 2022 | 02:37 AM
o1xjr's Avatar
Welcome to the forums.
Old Feb 4, 2022 | 07:42 AM
S-Type Owner's Avatar
From one S-type owner to another... Welcome. The S-type forum is populated with a very friendly group and contains a wealth of knowledge.
You might want to add your car's details to the available signature line; this helps us to help you when posting to the forums...
Old Feb 4, 2022 | 07:48 AM
Welcome to Jaguar Forums Pete,
Old Feb 4, 2022 | 09:03 AM
Hello, Pete,
Old Feb 4, 2022 | 11:47 AM
Old Feb 4, 2022 | 06:41 PM
user 7508230's Avatar
Banned
Welcome to the group! I’m sure there will be someone to get the information you need.
Old Feb 5, 2022 | 02:48 AM
Welcome to the Forums.
Kylemoorman94
Jan 10, 2022 08:58 AM
CatsDaddy
Mar 27, 2016 08:01 PM
khriss
Mar 20, 2013 11:02 PM
Ifexsa
Feb 5, 2012 06:01 PM
Greenbrook
May 3, 2011 08:19 PM
