restricted performance. 2000 XJ8
Old Sep 1, 2012 | 11:20 AM
eneryv111's Avatar
Default restricted performance. 2000 XJ8
Hi : I am a new member and would like to ask a question. Two or three times over the last few months My year 2000 Jag XJ8 has been giving me the message restricted performance and usually accompanied by engine hunting.I have used upper cylinder lube and various gas treatments and after a while it goes away ,usually day or so later. Today It started again and I happened to check the gas filler area ,it was full of water.Now that I think about it each time I went to put gas treatment in there was always water in that compartment.Now I removed the drain plug and sure enough it was blocked solid. Thats all cleaned now! Question could that be the problem?would just a little water in the gas create the decibed problem . Thanks. Ian
Old Sep 1, 2012 | 11:54 AM
Welcome to the forum Ian,
It is possible that you have hit on the fault.
You should get your codes checked to be sure, if you post in the tech section for your model XJ ( X308 ) XJ8 / XJR - Jaguar Forums - Jaguar Enthusiasts Forum you will get a better response.
Old Sep 1, 2012 | 12:05 PM
Good advice from Norri. Hope this is the solution to the restricted performance.
Old Sep 2, 2012 | 03:40 AM
Welcome to the forum.
Hope that it was just that simple solution.
Might take a while for all the water to work its way out though.
Good to see you.
Old Sep 2, 2012 | 01:01 PM
Hi eneryv111 & welcome aboard, good to have you here with us
Helpful_information
Why not drop in and visit the regional section for your area?
Old Sep 2, 2012 | 03:22 PM
avt007's Avatar
Welcome Ian. The water could be something, but I'd be surprised. Wait and see, I guess.
We do have a Canadian forum, the link is in my signature. Check it out, we've got lots of Ontario members.
Old Sep 2, 2012 | 06:32 PM
abonano's Avatar
Welcome to the forum Ian.
Great advice and pointers shared above.
Enjoy the forum - Anthony
Bcrary3
Sep 12, 2021 05:41 AM
Will P
Sep 19, 2018 08:36 AM
Will P
Sep 30, 2015 08:38 AM
corysansburn
Sep 10, 2015 06:15 AM
AtholC
Sep 9, 2015 09:07 PM
