Screen washer Help
Old Oct 2, 2021 | 02:27 PM
Hawera's Avatar
Default Screen washer Help
Asking for advice on how and where to access the underside of my windscreen jets on my 1967 Daimler / Jaguar 420. The left side on my car is loose and will likely leak on a wet day. All I want to do is to tighten it up. Hoping the method does not require all the doors and the back end removed from the car for this to be done.
Old Oct 2, 2021 | 02:52 PM
Welcome to the forums Hawera,
The Workshop Manual only covers adjustment and the Parts Catalogue shows them secured from below with a wing nut. Nothing useful such as fitting instructions! Follow this link https://www.jaguarforums.com/forum/mark-v-x-420g-58/ to the Mark V - X 420G forum for help, advice and information. The 'HOW TO' thread at the top is a good place to start for information on regular issues. You can also use the New Zealand Region forum by following this link https://www.jaguarforums.com/forum/new-zealand-97/ to find other members in your region.
Enjoy the forums.
Old Oct 2, 2021 | 05:57 PM
Daf11e's Avatar
Welcome aboard.
Old Oct 3, 2021 | 02:36 AM
Hawera's Avatar
Default Hawera
Hi all- struggling with the 'new member stuff' here. Where do I find the tab for "forum Signature' so I can fill in my detils. Also I cannot print off the page(s) of new member info so important to me, because the lines of type print over each other. I can read it easily on the screen, but cant print it so I can read it.. Cheers Malcolm
Welcome to the Forums.
Old Oct 3, 2021 | 06:25 AM
welcome to the forum - enjoy!!! To enter a signature, click on User CP on the upper left of the screen. Then look for settings and options and select Edit Signature. As for printing - may be best to select what you want to print and then when you click Print, change to Print Selection
Old Oct 3, 2021 | 07:44 AM
Welcome to the forum Hawera,
Old Oct 3, 2021 | 08:15 AM
Hello,
Old Oct 4, 2021 | 02:12 AM
Malcolm,
I added basic details to your for "forum Signature". If you want to change these, go to the User CP button on the left of the top menu bar, then Settings & Options under Your Control Panel. Select Edit Signature and enter the details.
How you print pages directly depends on the device you are using to access the forum and the choice of browser.
Old Oct 6, 2021 | 12:50 AM
o1xjr's Avatar
Welcome to the forums Hawera, I have added you to the NZ Roll Call thread.
https://www.jaguarforums.com/forum/n...2/#post2450224
Harty82
Oct 22, 2018 06:39 AM
maindivide123
Oct 18, 2018 03:12 PM
cplaar
Nov 14, 2012 07:45 PM
harry
Aug 21, 2012 08:36 AM
lntjp00
Jul 20, 2012 12:53 PM
