Solenoid fault
Old Aug 29, 2015 | 07:56 AM
Steve Langridge's Avatar
Default Solenoid fault
2.1 v6 x- type auto,as soon as drove the car it went from 1st gear into 2nd then limp mode,the warning code was p0753 solenoid fault, so I done the cheapest option first witch was to change the transmission fluid witch by the colour of it had never been done,anyway the fault was still there so I checked the solenoid wiring loom user the battery moved the wires gently and the bottom black wire witch was connected to the yellow wire came off,dry solder joint,connected this to yellow wire metered the other wires across the loom all ok job done .
Old Aug 29, 2015 | 09:26 AM
Hello, Steve,
Someone will be along shortly to direct you to the S-type section where you can get help for the solenoid problem.
Old Aug 29, 2015 | 05:28 PM
Welcome to the forum Steve,
Follow this link X-Type ( X400 ) - Jaguar Forums - Jaguar Enthusiasts Forum to the X-Type forum for help, advice and information.
You can also visit the UK & Eire Region forum by following this link https://www.jaguarforums.com/forum/uk-eire-68/
Enjoy the forums.
Old Aug 29, 2015 | 05:37 PM
<p>welcome to the forum- enjoy!!!</p>
Old Aug 29, 2015 | 05:39 PM
Daf11e's Avatar
Welcome to the forum Steve......and a fix...well done!
Old Aug 29, 2015 | 08:21 PM
o1xjr's Avatar
Welcome to the forum,
Herne Bay, Auckland or UK?
Old Aug 30, 2015 | 07:25 AM
Welcome to Jaguar Forums Steve,
Old Aug 30, 2015 | 12:38 PM
UK mate
Old Sep 3, 2015 | 07:35 PM
Using JF "How To"
JaguarLover101
48
Jun 12, 2023 10:28 AM
dmatthewman
Sep 30, 2015 10:10 AM
zoozth
Sep 29, 2015 07:28 AM
jjmiah217
Sep 28, 2015 09:09 AM
