X305 wiper problems
Old Aug 19, 2019 | 02:56 AM
Per Greibe Soerensen's Avatar
Default X305 wiper problems
When I start the wiper, there is a "thumping sound" the same thing happens when it stops, even when it runs on the wiper robot.When it is just running, there is no sound, even when it is passing the stop position.It sounds like something mechanical but since it only gives the sound when it stops and starts and not just running back and forth I have doubts .. Thinking about maybe there is a relay or similar.under the dashboard that sits loose.Is there anyone who has good advice before I start to break it all down??!?Greetings Per from Denmark
Old Aug 19, 2019 | 04:56 AM
Welcome to the forums Per Greibe Soerensen,
I see you have already found the XJS forum for electrical problems so there is no need for a link to it from me. For your other Jaguar, follow this link https://www.jaguarforums.com/forum/x...-x350-x358-28/ to the X305 forum for help, advice and information. However, with the wiper problem, you will probably find members in the X300 forum are able to help.The 'HOW TO' thread at the top is a good place to start for information on regular issues.
You can also use the Europe Region forum by following this link https://www.jaguarforums.com/forum/europe-42/ to find other members in your region.
Enjoy the forums.
Old Aug 19, 2019 | 05:01 AM
Welcome to teh Forums.
Lift the cover cap on the arm, and ensure the nut is tight, NOT stupid tight, you will break that spline stud, just sensible tight. They do loosen some times.
Good luck.
Old Aug 19, 2019 | 05:29 AM
o1xjr's Avatar
Welcome to the forums.
Old Aug 19, 2019 | 05:58 AM
Old Aug 19, 2019 | 07:22 AM
Welcome to Jaguar Forums Per,
Old Aug 19, 2019 | 08:30 AM
Hello,
Old Aug 19, 2019 | 10:59 AM
Default Problem solved
Thanks for the good advice, but I've solved the problem.It was the wiper motor itself.It was running very tight.I have therefore separated, cleaned, lubricated and reassembled it.Now everything seems perfect.Well - maybe not so strange for a 24 year old car.
Old Aug 19, 2019 | 01:11 PM
Good to hear you solved it.
Old Aug 19, 2019 | 03:53 PM
Daf11e's Avatar
Welcome aboard.
Old Aug 20, 2019 | 05:39 PM
jerry_hoback's Avatar
welcome, And good job sorting the problem.
MarkLee
Apr 17, 2014 11:30 PM
loveday
Oct 23, 2012 08:24 PM
djbw714
Mar 18, 2011 12:06 AM
