X350 main cooling fan
Old Nov 13, 2016 | 09:55 AM
mauriexj350's Avatar
Angry X350 main cooling fan
HI Guys
Can anybody through some light on an issues
When the car is running the main cooling fan is running at full speed. I had it checked to see if it was a fault with the actual fan, however that was not the case. Could this be the cooling sensor? The temperature is running at 1/2 way up the gauge.
Has anyone come across this before
Old Nov 13, 2016 | 03:00 PM
Hello,
Doubtless someone has encountered this problem before.One of the Moderators will be along soon to direct you to the correct section where members can help you.
Old Nov 13, 2016 | 03:28 PM
cat_as_trophy's Avatar
Welcome Maurie and greetings from down under.
Before directing you to the X350 forum where the gurus can answer your specific tech question, I would first jump to User CP on the main menu bar to Edit Signature and enter the year, model, engine, variant - so this vital info appears in all your future posts. This (trust me) is all the more critical when (like me) you are blessed with something rather more unique than the norm. While there, you can experiment with including pics . . . either Edit Avatar or using Manage Attachments below the typing box when entering posts.
So, dive in and enjoy!
Old Nov 13, 2016 | 04:08 PM
o1xjr's Avatar
Welcome to the forum
Old Nov 14, 2016 | 02:25 AM
Welcome to the forum mauriexj350,
Follow this link XJ XJ6 / XJ8 / XJR ( X350 & X358 ) - Jaguar Forums - Jaguar Enthusiasts Forum to the X350 forum for help, advice and information.
The 'HOW TO' thread at the top is a good place to start for information on regular issues.
You can also visit the UK & Eire Region forum by following this link UK & Eire - Jaguar Forums - Jaguar Enthusiasts Forum
Enjoy the forums.
Old Nov 14, 2016 | 02:43 AM
Welcome.
Old Nov 14, 2016 | 03:43 AM
Daf11e's Avatar
Welcome aboard.
Old Nov 14, 2016 | 06:22 AM
Old Nov 14, 2016 | 08:55 PM
Welcome to Jaguar Forums mauriexj350,
Old Nov 14, 2016 | 09:36 PM
Cambo's Avatar
The fan controller is programmed to "fail on" so the fan will run at maximum if there is a fault in the control circuit.
Could be a number of things that cause this, even something as simple as the signal wire from the engine ECU being open circuit.
