P1388 code
Old Jun 5, 2014 | 03:04 PM
Harleyfxs81's Avatar
Default P1388 code
I have a 2000 S-type 3.0 L with P1388 code.
Sent car to dealer, Jaguar Monmouth, Ocean, NJ. Asked dealer to correct the code for car to pass inspection.
Dealer stated the Powertrain Control Module, (PCM) sticker had the lastest SoftWare release "S139, 15, March 2001 ", and it is not worth it to re-install, because the engine and trans need to be replaced, (car runs fine).
Well, after viewing this site, I found out that no one should use this dealership for any repairs on older cars. They were too lazy to look up Tech Bulletin S303-9 and S303-S139, July 2002, I found on this site which hopefully will correct the problem.
Has any one used these updates to correct code P1388?
Last edited by GGG; Jun 25, 2014 at 10:00 AM. Reason: copied question from Intro thread
Old Jun 25, 2014 | 10:11 AM
I've copied the question about code P1388 from your Intro thread.
Members here with the same model will be able to help.
Old Jun 25, 2014 | 10:55 AM
JagV8's Avatar
What are your thoughts on the existing thread about this?
BTW, S139 appears to be the same thing you then describe as S303-S139
Old Jun 25, 2014 | 12:03 PM
fosterj's Avatar
Had the same code on my 2000 3.0. I had the PCM reflashed and changed the oil/filter. That was about 1500 miles ago and no codes since.
philwarner
Oct 4, 2024 01:37 PM
philwarner
25
Jun 26, 2021 05:43 AM
bdboyle
Sep 16, 2019 05:58 PM
Terry H
Jul 4, 2017 05:48 PM
JCam
Oct 23, 2016 08:27 PM
