'03 rear window operation.
Old Apr 10, 2012 | 09:48 PM
Mcavty's Avatar
Smile '03 rear window operation.
Neither switches in the back doors operating my rear passenger windows
work, despite the small oval switch ,in the centre of the four window switches in the drivers door ,being in or out.
The master switches in the drivers door operate all the windows OK.
The kiddie locks on the rear doors are off.
Does the drivers Memory switch affect the rear window switches?
Could a previous owner have had the dealer disable them?
I can find nothing in the hand book to assist - any suggestion will be gratefully received.
Old Apr 10, 2012 | 11:11 PM
Hartleys's Avatar
Hello Mcavty> I have a 2000 Jaguar S-Type. My is doing the same thing. I got a new switch for the driver's door but it did not help. I even unhooked the battie. No luck! Now after unhooking the battie my lock button on my keyless remote horn won't beep when I press the luck button twice like it use too. If you find out what going on with your windows please please lent me know and I'll do the same. Good Luck and Thanks
Old Apr 14, 2012 | 09:27 PM
Mcavty's Avatar
Ok hartley, I'll let you know when I find an answer - my vehicle is an '03 STR.
Old Apr 15, 2012 | 05:38 PM
Mcavty's Avatar
Smile
I've tried rebooting the computer by disconnecting the negative lead of the battery for 5 minutes - it has made no difference.
I have now found the rear door window switches work if the front drivers door is open & the gearshift is in "Park".
Any ideas anyone?
Old May 11, 2012 | 01:00 AM
Hartleys's Avatar
I don't know what happen but my window's started to work on my 2000 Jaguar S-Type 3.0. I didn't do nothing. I think I might have a loss ground some were.
Old Oct 28, 2012 | 10:56 PM
Hartleys's Avatar
Hi Mcavty! How have you been? Did you ever fine out anything about your window switches?
Old Oct 31, 2012 | 04:53 PM
Mcavty's Avatar
Hi Hartleys,
No joy yet in overcomming the rear window operation - the car is due for a service in january, so I'll ask the dealer to check if the operation can be switched on through their computer?
Will let you know the outcome!
Cheers.
Old Oct 31, 2012 | 05:07 PM
tbird6's Avatar
They all have the same problem. It's corrosion on the contacts. It's especially bad on windows not used much. Like the back ones. You can change the switch or take it apart and sand the contacts. If you do please coat the contacts with dielectric</SPAN> grease to help with the corrosion problems.
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
kevinl
Oct 31, 2019 06:15 PM
GordoCatCar
Jan 2, 2017 01:10 PM
Nigels420G
Mark V - X 420G
Sep 17, 2015 10:29 AM
