03 S Type - Front RH Indicator not working
Old Mar 27, 2012 | 09:35 PM
03JagSType3.0's Avatar
Question 03 S Type - Front RH Indicator not working
Greetings all,
Having an issue with the right hand turn signal not working. Both the side and back right hand turn signals work fine. I have checked the fuse and even replaced it with a new one with no luck (F8 with a 5A fuse). Also, the bulb is fine as I can move it to the left hand side of the vehicle and it works there.
I have been having trouble with the right, front signal for some time and was hoping that I could get some help troubleshooting the possible electrical issue.
I have the 2003 (or 2002.5) S Type electrical guide and curious as to how to troubleshoot it. My electrical skills are lacking but hoping to get some pointers.
Thanks in advance for your help
Old Mar 27, 2012 | 10:44 PM
LoganWolf's Avatar
I am having the same issue. I replaced both the 8 and 10 fuse in the passenger side fuse box. Fixed it for a few days but it ended up being the bulb socket holder. I have one on order. I found a good deal on it, hope it works. When I called the dealership they wanted a $100 bucks for it. I couldn't believe it. I had just replaced one on my wife's Jeep. It cost me $6.
Old Mar 27, 2012 | 10:49 PM
Default Good to know...
I was wondering if it was the bulb socket holder as well but could not find a part number for one. Before the only Jag dealer closed in STL, they wanted to sell me the complete light housing for the side, I don't remember the quote they gave me but it was alot.
Did you happen to find the part number for the socket?
Old Mar 28, 2012 | 03:52 AM
JagV8's Avatar
Try a few online parts places but if expensive try a wrecker or ebay, just make sure you get one suitable for your car.
Old Mar 28, 2012 | 05:48 AM
+1 on the bulb holder, IIRC they are either not available or horrendously expensive.
Old Mar 28, 2012 | 07:36 AM
abonano's Avatar
Guys, I came across a few of these turn signal bulb holders - XR855196 - I have 1 new and a few good used pieces and I also have the amber bulbs as well. PM me if your interested.
Old Mar 28, 2012 | 09:05 AM
Thanks all for your comments.
Abonano, I am interested in one of the holders but I believe since that I am a new member that I can't PM you yet. Can you PM me with a price? (** Edit - Nevermind, I found how to send a PM and I sent you one **)
I also found this thread about about the turnsignal issue and may give it a try until I get it replaced.
https://www.jaguarforums.com/forum/s...-failure-9459/
Old Mar 28, 2012 | 10:37 AM
I knew there was a thread somewhere!
I've cleaned mine up and bent the contacts and managed to keep it going, I see Brutal quoted $53 in that thread, I'd have thought $5 would be nearer the mark.
Old Mar 28, 2012 | 12:44 PM
Jon89's Avatar
Yep, burnish your bulbholder contacts and work with them before biting the bullet and spending the money to replace them. I've done this with a couple of different vehicles over the years and managed to get the bulbs working properly again. A little effort can sometimes save you from having to purchase an expensive replacement part....
Old Mar 29, 2012 | 08:52 AM
I have ordered a new socket to replace the current faulty socket. I have applied TBird6's described fix to get the turn signal to work again. I posted what I did and with pictures in the other thread (since that is where he posted what he did) to help anyone else having the issue.
I will post again once I have the new socket installed.
https://www.jaguarforums.com/forum/s...e2/#post490578
Old Apr 22, 2017 | 10:04 PM
Brad Engram's Avatar
Default I could use one of those turn signal bulb holders. How much ?
Old Apr 23, 2017 | 10:47 AM
clubairth1's Avatar
Community Influencer
Yes I am NOT proud of the repair but with over 70K miles on it now I guess it does work.
I am Tbird6 too as I have posted under both user names.
stanjag
Dec 29, 2024 08:26 PM
BrentGardner
29
Dec 16, 2024 12:13 AM
johnnie ryall
Oct 19, 2015 09:44 PM
Jandreu
Aug 29, 2015 07:31 PM
