03 STR parking sensors working no sound!
Old Jul 19, 2020 | 07:25 AM
scuby's Avatar
Default 03 STR parking sensors working no sound!
My 03 STR is coming along nicely and slowly but surely I'm going to have this thing better than new.
Current niggle is: rear parking sensors aren't emitting any sound or warning in the cabin.
I read some threads and thus checked for clicking and all four sensors are clicking as they should.
There is no audible sound inside the car. Not when passing reverse, never has been. I don't appear to have an on off switch.
Where is the speaker located? Seems the system.is being activated just simply isn't making sound. Ideas?
Old Jul 19, 2020 | 08:27 AM
clubairth1's Avatar
Community Influencer
Yes it's a strange little speaker in the dashboard. Sometimes I have heard it called a "sounder".
Not common for them to go out so I can't guide you on where the speaker is. Also was not serviced separately so they had to find a used one.
Sorry for the weak bit of help!
Old Jul 19, 2020 | 09:11 AM
S-Type Owner's Avatar
I believe the sounder unit is located under the rear "hat shelf" beneath the rear windscreen.
Old Jul 19, 2020 | 03:20 PM
scuby's Avatar
Couldn't find much
Also noticed my alarm makes no sound. Anyway these two could have been turned off?
Old Jul 20, 2020 | 12:40 PM
clubairth1's Avatar
Try this as those are not the speakers your looking for.
Those are your 2 sub woofers.
It's under the rear parcel shelf and you need to remove both sections of your rear seat.
Speaker Location
Old Jul 21, 2020 | 09:35 AM
Before you start tearing things apart... If your trunk has ever leaked (and what S-type has not...) there may be corrosion on the connections to the parking aid module. The module is mounted on the left hand side of the spare tire well in the trunk/boot of the car. I would recommend cleaning the contacts on the module and connector prior to disassembly of the interior...
Old Jul 22, 2020 | 05:09 AM
JagV8's Avatar
Dangerous to say but mine hasn't leaked.
Old Jul 22, 2020 | 05:10 AM
M-e-l-l-o-w's Avatar
I was going to say one of the common faults with the parking sensors is water damage to the control unit in the trunk/boot.
I would also look at that first, it may need replacing.
The factory default is that alarm will make no sound when it is set and unset, other than the locks working. (I think this can be changed if you use the Jaguar software.)
Obvioulsy it should make a noise if it is set off!
Mellow
WAIMEA1
Sep 7, 2017 06:33 AM
johnban
Jan 28, 2015 12:07 PM
Jaygee
Aug 21, 2013 07:23 AM
Jag944
Mar 28, 2013 10:11 PM
wigglewerks
Jun 3, 2011 01:41 PM
