'04 S-Type R Running Hot
Old Feb 12, 2014 | 09:05 AM
mrsambem's Avatar
Originally Posted by androulakis
Ok first. To bleed it completely. Put a floor jack on the frame behind the passenger side tire, and raise that side of the car a bit. - No need to get a tire off the ground.
Jack my passenger side (UK) or yours? My left or right if I'm sat in the car looking forwards?
Old Feb 12, 2014 | 09:36 AM
androulakis's Avatar
I forgot that you guys drive on the wrong side of the road..... Your driver's side. Your right side if you are sitting in the car.
The point is to raise the coolant tank a bit and make the heater valve higher than the lowest point.
Take care,
George
Old Feb 12, 2014 | 06:35 PM
clubairth1's Avatar
Community Influencer
Don't worry about bleeding the inter-coolers. They will bleed fine on their own. I have never removed the big hex plug and I am at 98K miles.
I have found the STR does a good job of getting the air out with a few heat and cool cycles. Just keep checking the top tank and adding coolant as needed. After about 4 or 5 days I am usually done.
Old Apr 15, 2014 | 07:54 AM
LeoJagger's Avatar
Talking ?
Unqualified comment.
Old Apr 15, 2014 | 03:10 PM
Docuzzie's Avatar
Originally Posted by Wuzupez
Hope it wasn't washer fluid. I believe honda and BMW have blue coolant from factory. Possibly the newer Nissans as well use blue
I'm not the Doctor on these cars, but... the Antifreeze or coolant should be Orange. If it was blue, that might be your problem or a serious contributor to your problem.
Old Apr 16, 2014 | 06:41 AM
mrsambem's Avatar
I did thermostat + water pump as advised, and flushed out the green/blue coolant to replace with the proper spec orange. Took a few miles and a few small topups to fully bleed but seems to hold a level now. This has brought the running temp (as read from test mode on console) down to around 98-101C which I believe to be acceptable. I do note that the fan seems to be on high quite often when stationary at the lights etc though.
Old Apr 17, 2014 | 03:17 AM
LeoJagger's Avatar
Lightbulb
Please see
Go LPG - Common X350 faults
They blame the thermostat housing.
Hope it is the same as in your S-Type.
BTW for which brand of gas equipment did you install ?
Were there any additional components installed ?
Old Apr 19, 2014 | 09:59 AM
  #28
Wuzupez's Avatar
Do you have a source for discounted factory parts? You will need it! Here in the US we have a forum sponsor that treats us pretty well. 15% off list and free shipping for anything over $25 plus no sales tax.
Where do we get this discount/parts from? I am in need of a new DCCV valve!
Old Apr 19, 2014 | 10:07 AM
clubairth1's Avatar
Check around but I found Amazon pretty competitive on price for the DCCV. Remember there are only 2 styles for ALL Lincoln LS and Jaguar S Types. 3 hose and 5 hose versions.
Just be sure to get the right one for your car.
cissdm
May 3, 2016 06:02 AM
user 652867429824
Sep 5, 2015 12:53 PM
Corycarlo
Sep 5, 2015 11:41 AM
pocketrocket
Sep 3, 2015 07:44 PM
