1999 S-type battery discharge
Old Jan 11, 2013 | 05:35 PM
britishracinggreen's Avatar
Default 1999 S-type battery discharge
Last week I discovered a rain leak in the boot, which I understand from forums is not uncommon. The battery had gone flat which I put down to the damp in the boot. I dried the boot.
I fully recharged the battery, drove the car fine. Covered it for the week, to keep out any more rain, but alas when trying it tonight the battery was again flat. Is there any chance of the wiring causing a short in the boot? Is this also common? or do I have a battery problem, the battery is only 6 months old.
Old Jan 11, 2013 | 05:46 PM
I've moved your tech question to the S-Type section for input from more members with the same model.
Old Jan 11, 2013 | 08:31 PM
bfsgross's Avatar
BRG, check for the obvious, such as loose and/or corroded battery terminals. A weak alternator may also exist. Test the battery with engine off (12 volts) and also running (14 volts).
Old Jan 11, 2013 | 09:11 PM
Mikey's Avatar
It's possible that the electronics that became wet are putting a constant draw on the battery. Try disconnecting it when the car is not in use to see if it keeps a charge.
Dagny
Jun 11, 2024 01:06 PM
Rivguy
Nov 13, 2022 02:55 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
DuhCar
Sep 11, 2015 10:58 AM
DEklof
Sep 8, 2015 05:28 PM
