2000 S-Type
Old Feb 18, 2016 | 05:25 PM
JagnJeep's Avatar
Default 2000 S-Type front end shake starting
Consistent light vibration while driving, not major at all and does not increase while turning or anything. Also, occasionally when starting from a parked spot, there will be a quick front end shake. 51,000 miles. Any ideas?
Old Feb 18, 2016 | 06:00 PM
JagV8's Avatar
Maybe misfires.
Old Feb 18, 2016 | 07:41 PM
abonano's Avatar
+1 on one or more intermittent misfiring coils.
Old Feb 19, 2016 | 09:50 AM
JagnJeep's Avatar
Thanks for the reply. What parts need replacing?
Old Feb 19, 2016 | 09:53 AM
Jon89's Avatar
Depends upon what's wrong. First things first - get the OBDII codes read to confirm misfires. Where are you in North Carolina?
Old Feb 19, 2016 | 10:07 AM
JagnJeep's Avatar
Default 2000 s-type shake / misfire
Yes. Winston / Gboro area. Seems odd that a misfire would cause the steering wheel/front end shake. I would have thought suspension related. if it is not giving error messages, will it still reveal codes?
Old Feb 21, 2016 | 09:34 PM
Warspite's Avatar
You'll usually get a check engine light. Either coil on plug is going out, or, spark plug is worn (too wide a gap from wear) or carbon/oil fouled.
If you see it in a steering wheel that is oscillating, it could be wheel or tire related (no mention if the car is in Park, or driving).
Old Feb 23, 2016 | 07:04 PM
davidladewig's Avatar
Tires? Maybe a bearing? I would check tires first because some of them go square when they sit or the lugs loosen, etc.
TexMurphy
Mar 16, 2016 07:40 AM
BSV205F
Feb 17, 2016 10:26 AM
nasomi
Feb 16, 2016 10:35 PM
Timmy Gibson
Feb 15, 2016 11:46 PM
Timmy Gibson
Feb 12, 2016 06:44 PM
