2000 s type 3.0 manual warning Lights!
Old Jan 16, 2015 | 05:06 AM
jas31's Avatar
Default 2000 s type 3.0 manual warning Lights!
My s type threw on all the brake warning lights this morning ( brake abs traction control )
After restarting the car it reset itself hasn't done it again
gonna put on a diagnostic to check it just a bit bizarre and random thing that happened
Old Jan 16, 2015 | 05:41 AM
JagV8's Avatar
Probably low voltage - flattish or failing battery
Old Jan 16, 2015 | 06:09 AM
Battery should be your first check.
Old Jan 16, 2015 | 01:12 PM
joycesjag's Avatar
I am surprised that no one has mention to check the battery.......
Old Jan 16, 2015 | 08:15 PM
tony1963's Avatar
I would strongly recommend checking the battery first.
I'm surprised someone hasn't already brought that up.
Old Jan 16, 2015 | 09:02 PM
Gus's Avatar
Gus
What they said!
Old Jan 17, 2015 | 01:01 AM
Mikey's Avatar
You're all out to lunch.
It's probably the battery.
Old Jan 17, 2015 | 10:50 AM
Jumpin' Jag Flash's Avatar
From: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
Is there any chance at all that this could be a failing battery?
Old Jan 17, 2015 | 11:30 AM
abonano's Avatar
Originally Posted by jas31
My s type threw on all the brake warning lights this morning ( brake abs traction control ) After restarting the car it reset itself hasn't done it again gonna put on a diagnostic to check it just a bit bizarre and random thing that happened
B A T T E R Y - like everyone else here is pointing to...
Old Jan 17, 2015 | 01:51 PM
Gus's Avatar
Gus
Should I check the Battery?
Old Jan 17, 2015 | 02:23 PM
abonano's Avatar
lol!
Old Jan 17, 2015 | 02:47 PM
jas31's Avatar
Default jaguar s type 3.0 manual
update
Found No Problems when plugged it in to the diagnostic machine
Thanks for all the replies yes its the Alternator playing up
Old Jan 17, 2015 | 03:53 PM
Gus's Avatar
Gus
Alternator! Glad you found the problem.
X_Type_South_Africa
Dec 9, 2015 05:37 PM
h4wk
Nov 27, 2015 05:10 PM
tberry6686
Sep 20, 2015 03:22 PM
Oliver9218
Sep 3, 2015 05:33 PM
EastFalk
Aug 29, 2015 08:22 PM
