2000 s type 4.0 sucking oil into throttle body
Old Jun 23, 2022 | 09:59 PM
Chriswood0512's Avatar
Default 2000 s type 4.0 sucking oil into throttle body
I have a s type with 71000 miles. New plugs and replaced three coils. New timing chains and guides and tensioners. It has recently started smoking and sucking oil through the intake tube from the driver side valve cover. I drilled out the port on the passenger side valve cover port and it seemed fine. Then while I had it on ramps to recharge the ac it started smoking really bad after it came of the ramps. I drove it for 10 miles and it smoke everytime it went above 2500 rpms. I took the intake tube off and opened the throttle body blade and can see it's coated with a heavy coat of oil inside. I thought about deleting the tube running from the driver side valve cover to the intake tube, since that is where it's sucking the oil from. Putting a filter on the valve cover and capping the intake tube. I am lost and need direction.
Old Jun 24, 2022 | 09:52 AM
motorcarman's Avatar
Make sure BOTH cam covers have free flowing pathways/breathers.(especially the one to the air cleaner)
Clogged mesh screens in the cam covers can create pressure?
Old Jun 24, 2022 | 03:39 PM
Can I just remove the mesh?
Old Jun 24, 2022 | 03:54 PM
The mesh area is a sort of OIL SEPARATOR.
Old Jun 24, 2022 | 04:08 PM
Well what can we do for it? I tried engine degreaser when I had it apart for the timing chains. Didn't seem to help
Old Jun 24, 2022 | 06:30 PM
S-Type Owner's Avatar
Most metallic mesh screens can be cleaned with mineral spirits, brake cleaner, etc. Engine degreaser is mostly diesel fuel, IIRC, and lacks the ability to break down the varnishes that hold the "goo" to the mesh...
Old Jun 24, 2022 | 11:05 PM
I have run a compression check. All cylinder were above 146-175. I saw no cylinders low side by side and watched each one for about 5 mins. Didn't see any leaking down. Several plugs were fouled out and had oil build up on them. Wondering if the compression rings could be good and the oil control rings be bad?
Old Jun 25, 2022 | 06:12 AM
If your engine was produced prior to August 2000, it will have nikasil cylinder liners which can be troublesome:
JagRepair.com - Jaguar Repair Information Resource
The Coupe
Jun 10, 2025 12:30 PM
talashek
Nov 26, 2015 12:18 AM
randyb
Apr 13, 2012 09:48 AM
xj8xj8
Nov 9, 2009 09:08 AM
Rlover
Apr 8, 2009 07:39 AM
