2000 S-Type Dash Trim
Old Jan 28, 2010 | 03:06 PM
mep's Avatar
mep
Default 2000 S-Type Dash Trim
I noticed a crack on the dash wood trim and would like to replace/repair it. Does anyone know how to take this off? Does the entire dash have to be dismantled? Or, Does it just pop off? I don't want to take the chance and damaging it more than it already is.
Thanks,
Mike
Old Jan 29, 2010 | 02:17 PM
mep's Avatar
mep
FYI, I looked at the JTIS and found nothing in regards to removing the wood trim from the dash.
Old Jan 29, 2010 | 02:42 PM
MyBlackCat's Avatar
Dealer removed mine for repair before warranty ended. Put a temp wood dash in place while it was out to be refinished.Don't think it could of been drivable without the temp piece in place. Was gone 3 weeks before it was reinstalled.
Don't know if this helps but gives you some info on the temp part.
Old Jan 29, 2010 | 03:29 PM
JOsworth's Avatar
I'm at work taking a bit of a break so I don't have access to my JTIS.
So, try this. Search for the procedure to replace a part that you know is buried deep in the dash, like a heater core or blower. That should have a part in it that tells you how to pull the dash trim.
Old Jan 29, 2010 | 06:32 PM
mep's Avatar
mep
I'll check it out and see if i can find something, thanks for the input.
Old Feb 21, 2015 | 06:16 PM
N8head's Avatar
Default Plastic dash trim cracked
Hey everyone. I have a 2000 S-type and the plastic trim that touches the windshield cracked when I was defrosting. I keep looking online and all I see are dash kits etc. Does anyone know what that plastic piece is called and where I can find one? Thank you in advance for your help.
Old Feb 21, 2015 | 06:52 PM
Warspite's Avatar
You are not alone. My 2002 is cracked in the exact same spot. Looked at 2 possible donors on Craigslist and one was missing and the other split in 3 places. Must be common.
Old Feb 21, 2015 | 07:06 PM
NBCat's Avatar
I have a 2000 S-type and the plastic trim that touches the windshield cracked when I was defrosting...Does anyone know what that plastic piece is called and where I can find one?
If I understand you correctly, you are referring to the demister grille, which runs along the top of the fascia just below the windscreen to direct air onto the glass. If this is indeed the part you are describing, they are available in different colours to match the interior components.
You need to provide the VIN and interior colour code or colour name so the correct part can be ordered from Jaguar.
Old Feb 21, 2015 | 07:16 PM
Sonspit's Avatar
Must be common.. my 2004 I'd cracked right down the middle.
Old Feb 21, 2015 | 07:17 PM
Sonspit's Avatar
Old Feb 21, 2015 | 08:02 PM
abonano's Avatar
Originally Posted by Sonspit
Replacement part is around $250 - $300 from a Jaguar parts supplier and they rarely come up on eBay as the cracking is quite common...
Old Feb 21, 2015 | 08:38 PM
Sonspit's Avatar
Saw some on eBay for around 80.00 but 99.99 for shipping..
Old Feb 21, 2015 | 09:44 PM
abonano's Avatar
from UK I take it... Spend the extra $50 and get a brand new replacement...
Old Feb 21, 2015 | 09:56 PM
Warspite's Avatar
That's the problem with large parts on EBay...shipping is high. I wouldn't give up on Craigslist but that's a needle in a haystack. And you have to be first in line when one does come up. Some of these non-dealer repair places that specialize in Jaguar and others have a yard full of donor cars that may have a good one.
Good luck!
Old Feb 22, 2015 | 03:15 AM
Paul792's Avatar
If it is the dash board air vent. The part numbers are XR823483 (right) XR823484 (left).
If you google just the part number then a number of sellers will come up.
Old Feb 22, 2015 | 10:13 AM
NBCat's Avatar
I believe the part being sought is the demister grille, which has a part number based on the matching interior colour and VIN.
Old Feb 22, 2015 | 09:20 PM
Paul792's Avatar
N8Head I am sorry for posting the wrong part and part number. It is XR825142 with a 3 letter code for the colour as NBCat has mentioned. For instance, XR825142LEG is black.
This link has them. But postage (as mentioned in the above posts) is expensive.
If you decide to go with this company perhaps a third party shipping agent would be less expensive. It is only a small part with minimal weight. It is also in used condition so may not be worth the effort.
DASHBOARD DEMISTER GRILLE SABLE / TOP VENT - Jaguar S-Type 1999-2002 | eBay
Old Feb 22, 2015 | 10:03 PM
Paul792's Avatar
Thanks,
Mike
Mike
There are discussions posted on the forum about this. I have not attempted to remove the wood myself (prepared to live with the crack as not confident enough). The discussion in the link below deals with your model with photos and a link to a restorer and post 12 has good removal information. However, if you search you will find more out there.
https://www.jaguarforums.com/forum/s...on-info-42730/
00 01 02 Jaguar s Type Dash Trim Panel Bezel Wood Good Condition | eBay
Old Feb 23, 2015 | 08:45 AM
N8head's Avatar
Default Thanks!
Thank you for all of the quick responses. I'll look to see what I can find this weekend. I'll let you know what I can find.
Old Apr 30, 2015 | 02:13 PM
stevedask's Avatar
Anyone know what is required to replace this demister grille part?
