2001 S 4.0 full timing chain replacement
Old Jul 29, 2019 | 10:46 PM
abonano's Avatar
Yes, slightly shorter bolts are in order and the slack should be taken up once oil pressure builds in the tensioner.
Old Jul 29, 2019 | 10:55 PM
Jim Blaine's Avatar
We are thinking maybe the secondary chains should be replaced too.. Thoughts?
Old Jul 7, 2022 | 06:34 AM
kansanbrit's Avatar
Originally Posted by NBCat
  • The engine is to be rotated in a clock direction only when viewed from the front of the vehicle. Rotating the engine in an anti-clock direction results in damage to the main and rod bearing shells.
can anyone explain this to me?
Old Jul 7, 2022 | 08:11 AM
S-Type Owner's Avatar
Bearing shells have tapered projections that hold them in place against the direction of engine rotation...
Old Jul 8, 2022 | 07:31 AM
kansanbrit's Avatar
Thanks but I don't think that is the reason, most engine shells have those. The AJ133 5.0 doesn't actually but should still not be rotated backwards. Personally I believe it is because the timing chain may skip if turned backwards because the tensioners go slack.
Old Jul 9, 2022 | 08:31 AM
Kansanbrit: Your reason sounds good to me...
slanham
General Tech Help
Feb 1, 2014 06:34 PM
Translator
Jun 2, 2012 11:26 AM
kdross
Sep 9, 2010 08:08 AM
