2002 S Type Steering Column Locked
Old Mar 5, 2024 | 11:03 PM
Dani12's Avatar
Default 2002 S Type Steering Column Locked
Greetings,
My electronic steering lock has failed. Is it possible to reprogram the cluster using IDS and disable the steering lock functionality all together? Please only share from experience. Thank you!
Old Mar 6, 2024 | 09:25 AM
xalty's Avatar
2002.5 or 2002? totally different cars
i have no experience with the og s-type but the x202 you can reprogram the cluster and unplug the column lock module and you’re good to go
Old Mar 6, 2024 | 09:29 AM
Dani12's Avatar
Thank you for your reply.
2002.5 :
ModelS-TYPE 1999 - 2008 (X200) CLASSICDate of productionJun 13, 2002Power Unit Variant3.0 Litre petrolTransmission Variantmanual
I think this makes it an X202?
If so, can you kindly elaborate on the cluster reprogramming for steering lock elimination? Is it done with IDS by configuring the cluster as "new"? Will I need 2 keys?
Thanks a lot
Old Mar 6, 2024 | 09:42 AM
xalty's Avatar
2002.5 :
Thanks a lot
yes it’ll ask you to answer configuration questions including if the column lock is fitted. you’re gonna also gonna have to get the drop the column to get the calibration code for the motors.
if you’re lazy you can go on ebay and find a code from another car, usually works but sometimes you can find trouble
Old Mar 6, 2024 | 09:47 AM
Dani12's Avatar
Do you recommend a specific version of IDS (or SDD)? I have bought a VCM1 already.
And just to confirm, I will be able to configure it even though the "STEERING COLUMN LOCKED" message is currently showing?
Thank you
Old Mar 6, 2024 | 02:38 PM
S-Type Owner's Avatar
Dani12: You indicated in one of your multiple posts to other sub-forums that your car was imported from the U.S.
Just so that you know, there was no 2002.5 mid-year model here in the States. The 2002.5 model was a 2003 model here in North America. If your car has the "Darth Vader" (as opposed to the "horseshoe") upper console treatment then it is an X200, 2002 model.
As an FYI, my 2003 has no steering column lock as it was not required in the U.S. at that juncture.
Old Mar 6, 2024 | 07:16 PM
motorcarman's Avatar
The S-Type steering column is a strange unit and Jaguar issued several warnings about improper configuration.
Here are some documents related as well as info I remember when configuring an INSTPK.
I went to NP2000 (S-Type introduction training) and we were warned about the NON LOCKING COLUMN.
When configuring an INSTPK to an S-Type, you must tell WDS/IDS it if it has COLUMN LOCKING!
North American cars must answer NO.
If the configuration answer is YES, then the INSTPK will FOREVER display a fault with the column and Jaguar would NOT warranty replace or compensate the dealer.(you bought it)
North American cars have no column lock as S-Type Owner has indicated.
The MY you actually have might determine what can be done.
I do remember having more info but a few decades have a way of hiding documents?
File Type: pdf
File Type: pdf
Old Mar 6, 2024 | 07:58 PM
Dani12's Avatar
All,
Thank you for your responses.
The car is definitely a USA car, I brought it from there. Date of production is Jun 13, 2002; the car definitely has an electronic column lock.
What I need to know (and it's probably asking too much) is if when the cluster reaches a 'STEERING COLUMN LOCK' state, is it possible to reconfigure it as a new cluster and tell IDS it has no electronic steering column lock, and the existing cluster will take the programming?
Old Mar 7, 2024 | 09:29 AM
scrannel's Avatar
I'm sure you've covered this by now, but when I first got my S-Type the ignition was actually beeping like crazy. I charged the car battery and have never heard a peep since. Your battery is for sure OK, right?
Also... did any modern S-Types in the US actually come with a column lock?
Old Mar 14, 2024 | 03:08 PM
xalty's Avatar
all NAS manual cars have a column lock
Old Mar 14, 2024 | 03:29 PM
scrannel's Avatar
So we had manual cars in the US?
Old Mar 14, 2024 | 03:30 PM
xalty's Avatar
yes 3L only
Old Mar 16, 2024 | 04:20 AM
Beretta9's Avatar
Smile
Wait, so the 00-02 have a darth Vader dash? Or the later models. Definitely sounds pretty cool but cannot see the comparison.
DOCKERS
25
Mar 18, 2024 09:44 AM
Aarcuda
Oct 20, 2020 08:51 PM
mhamilton
Feb 5, 2019 09:51 PM
lovelylellops
May 17, 2013 06:09 AM
u102768
Aug 20, 2011 04:44 PM
